How to decharge NiCad batteries?
7 replies to this topic
#1 Dan Salzmann
Dan Salzmann
  • 1143 posts
  • Paris, France
Posted 10 July 2007 - 06:43 PM
I've changed NiCad cells in two battery packs and I need to charge them (easy, just use a charger!) and discharge them (to avoid the memory effect and also for them to hold a longer charge after I recharge them) before charging them again.
Question is: Is there a way of decharging them without using them to power an empty camera for example?
Hope all this makes sense.
#2 David Venhaus
David Venhaus
  • 129 posts
  • Wiseburn, CA
Posted 11 July 2007 - 12:19 AM
Some charging units have a discharge function built in. On them you simply flip the switch to discharge and turn it on and it dischranges the battery. Those units will usually have a meter so as to know when the discharging is complete.
#3 Dan Salzmann
Dan Salzmann
  • 1143 posts
  • Paris, France
Posted 11 July 2007 - 04:21 AM
Sadly my charger does not have that function. Any other way to do this without running the camera?
#4 timHealy
timHealy
  • 1262 posts
Posted 11 July 2007 - 06:38 PM
Able Cine Tech use to sell something called a DX2 discharger just for this purpose.
Best
Tim
#5 Tony Brown
Tony Brown
  • 689 posts
Posted 14 July 2007 - 07:30 AM
Any RC shop will help you
#6 Andrew Rawson
Andrew Rawson
  • 57 posts
Posted 14 July 2007 - 11:37 AM
Tony is right. I fly RC helicopters as a hobby and battery management is a very important part of it. I've included a link below that has several chargers. The standard in the RC world is the Triton but I personally own the Hobbico and prefer it. The Hobbico allows you to charge 2 batts at the same time. It will discharge and it handles all battery types as well; Li-Ion, Li-Po, NiCd and NiMH.
http://www2.towerhob...wti0093p?&C=PKL
#7 Dan Salzmann
Dan Salzmann
  • 1143 posts
  • Paris, France
Posted 16 July 2007 - 09:46 AM
Thanks guys!
#8 David Auner aac
David Auner aac
  • 1117 posts
Posted 24 July 2007 - 12:34 PM
Hi Dan,
I have a pretty cheap multi-charger (by Conrad Electronics, check out this link).
This unit will charge and discharge NiCad und NimH batteries and packs, anything between 1-20 cells. You can use banana plugs to make any adapter cable you might need. It also features a number of nice refreshing and cycling programs.
If you don't have a discharger available, just use a number of 12V bulbs! ;)
Cheers, Dave
Edited by David Auner, 24 July 2007 - 12:36 PM.
