Can i work in HD wtih the knowledge of DV???
11 replies to this topic
#1 Mukesh Chander
Mukesh Chander
  • 31 posts
Posted 12 July 2007 - 07:21 AM
I can work in all DV cameras. But i never done a project in a HD camera. And now i am gettin a job in a production house where i need to work in HD. I have the confidence in me and have the courage to take up the job. But before tat can i know from u professional HD cameramans, is tat possible for me to develop my knowledge on hd by directly working on it? [I have attended a workshop on Varicam] Is there any special care to be taken in lighting for hd cameras? If so can u explain me or can u just tell me where can i find some help on the subject lighing for hd in any websites.. Or wat else should i do before taking up the job??? thanks in advance!!
#2 Nate Downes
Nate Downes
  • 1638 posts
  • Florida, USA
Posted 20 July 2007 - 06:07 AM
HD is DV. DV just means Digital Video, and HD is a form of DV. While HD offers you more, the skills between the two are virtually identical.
#3 jan von krogh
jan von krogh
  • 454 posts
Posted 20 July 2007 - 06:47 AM
Things that might be quite different vary quite a bit, depending on what DV-cameras you have been using so far and what HD-cameras youwill be using.
- external optics require you to check backfocus
- focus itself is much more critical, depending on the shoot at hand you will have to measure or require an excellent viewfinder, which is often not available (sony hdvfc, accuscene EVF or arri d20 optical)
- most top-class hd-cameras (sony, arri, panasonic, panavision, thomson, s:i) offer several pretty creative functions inside of the camera. Dependent of the producer/director, they might expected you know how to handle them.
but without more precise information with which cameras you worked so far, and which you will be using in the future, it is pretty hard to give more than general advice.
#4 Phil Rhodes
  • 12175 posts
Posted 20 July 2007 - 07:21 AM
In general you'll be OK. The only real difference is the criticality of focus.
Beyond that there's nothing you absolutely couldn't have come across in SD DV. Other correspondents are correct to warn you that HD cameras may have more complex menu options, but you aren't duty bound to get involved with all that unless you have a reason to.
Phil
#5 jan von krogh
jan von krogh
  • 454 posts
Posted 20 July 2007 - 07:26 AM
Carefull Phil, all depends on the camera he will be using...
- arri/gv raw modes...
- sony different color spaces....709 vs. rgb etc
- panasonic overcranking in varicam
etc
#6 jan von krogh
jan von krogh
  • 454 posts
Posted 20 July 2007 - 07:37 AM
mukesh, you would need to give us more information about the type of camera you will be using...
#7 Mukesh Chander
Mukesh Chander
  • 31 posts
Posted 21 July 2007 - 06:08 AM
i have used panasonic DVX 100, sony PD 170, canon XL1 [DV]. And i think i need to work in a varicam[HD].
#8 Brian Drysdale
  • 5198 posts
Posted 21 July 2007 - 06:30 AM
Those pro-comsumer cameras are operationed differently compared to the manual zooms used on the Varicam and other high end cameras, so there's a steep learning curve.
If you'd been shooting with a Sony DSR 570 or DSR 500 or other SD broadcast ENG cameras, the basic operating principles would be pretty similar.
#9 Mukesh Chander
Mukesh Chander
  • 31 posts
Posted 25 July 2007 - 08:40 AM
Sony DSR 500 shoots in hd or sd?
#10 Brian Drysdale
  • 5198 posts
Posted 25 July 2007 - 08:56 AM
The DSR 500 is DVCAM - that is SD.
#11 Mukesh Chander
Mukesh Chander
  • 31 posts
Posted 28 July 2007 - 04:43 AM
So can i be skilled in hd by just working with it? I am going to do music videos, docus, short films.. in tat. So step by step can i learn by myself abt hd or do i need to go to a film school?
Edited by Mukesh Chander, 28 July 2007 - 04:45 AM.
#12 Brian Drysdale
  • 5198 posts
Posted 28 July 2007 - 05:45 AM
You won't be skilled in HD by using a DSR 570, but you'd have the basic knowledge that can be used to get started on cameras like the Varicam.
Given the questions you're asking I suspect you'd need to go to be trained, since your basic knowledge don't seem to be that good. Most trainee camera assistants know more, so you really need to hit the books.
