FCP Crash
7 replies to this topic
#1 David Ralph Smith
David Ralph Smith
  • 2 posts
  • Atlanta, GA
Posted 12 July 2007 - 09:39 AM
I am Running OSX 10.3.9 and Final Cut Pro 5. Every time I try to run it, it crashes. How do I fix this?
I have reinstalled it. I also ran all of the updates that came up on "software update".
All of the other programs in the suite are working (Soundtrack, Live Type, DVD Studio Pro).
It's just Final Cut Pro that won't work.
#2 Dan Goulder
Dan Goulder
  • 1259 posts
Posted 12 July 2007 - 09:58 AM
That may be your problem. I may be wrong, but I believe the latest updates are supposed to work with OSX 10.4.
#3 Tenolian Bell
Tenolian Bell
  • 907 posts
  • Brooklyn, NY
Posted 17 July 2007 - 09:27 AM
Final Cut 5 was designed to run on Tiger. You need to update to OS 10.4
#4 Dan Goulder
Dan Goulder
  • 1259 posts
Posted 17 July 2007 - 10:31 AM
Actually, FCP 5 was designed to run on Panther (10.3.9). The latest version of FCP 5 (5.1.4) is designed to run on Tiger (10.4). If you don't want to change the operating system, you need to reinstall an earlier version of FCP 5 that will run with OSX 10.3.9.
#5 Tenolian Bell
Tenolian Bell
  • 907 posts
  • Brooklyn, NY
Posted 17 July 2007 - 11:21 PM
Tiger 10.4 was released on April 29th 2005. FCP 5 was released in May 2005. FCP 5.1 is the universal binary version of FCP 5 that runs natively on both Intel and Power PC Macs.
If David wants a stable system using Panther 10.3.9, he needs FCP 4.5.
#6 Dan Goulder
Dan Goulder
  • 1259 posts
Posted 18 July 2007 - 11:03 AM
OK, my turn. You are correct that FCP 5.1 was designed to run on OSX 10.4. However, FCP 5.0 was originally designed to run on OSX 10.3.9 (Panther) or higher (Tiger, 10.4). Since his original post clearly stated that he was trying to run FCP 5 on OSX 10.3.9, I suggested he reinstall the earlier 5.0 drivers for that reason alone. That will work.
#7 Tenolian Bell
Tenolian Bell
  • 907 posts
  • Brooklyn, NY
Posted 19 July 2007 - 12:29 PM
Apple made extensive changes to image rendering and processing in Tiger, as well as updates in OpenGL. Entirely new video and audio API's were developed called Core Video and Core Audio which aren't available in 10.3.9. FCP 5 and Quicktime 7 will look for Core Video and Core Audio to use. While they can work without the API structure, stability and crashing can be an issue.
#8 Keith Mottram
Keith Mottram
  • 824 posts
Posted 25 July 2007 - 05:06 AM
just picked up on this thread, your problem could well be that your quicktimen is too advanced for your version of FCP this has been known to cause issues - have you updated your quicktime beyond a panther build?
