60KVA
#1 Ken Minehan
Ken Minehan
  • 168 posts
  • Singapore
Posted 13 July 2007 - 01:18 AM
Hi guys, i want to confirm something with you guys. When using a generator that has a limit of 60KVA, does that mean that i can draw 60,000w from it?
thanks
Ken Minehan
#2 Chayse Irvin
Chayse Irvin
  • 409 posts
Posted 13 July 2007 - 01:42 AM
Its a 60,000W Genny, but try not to ever draw a full load off a generator, its bad for it. It will probably over heat if its hot out before you even get to a full load.
#3 Ken Minehan
Ken Minehan
  • 168 posts
  • Singapore
Posted 13 July 2007 - 04:07 AM
ok, i understand. Thanks for the reply.
regards
ken Minehan
#4 XiaoSu Han
XiaoSu Han
  • 162 posts
Posted 13 July 2007 - 05:39 AM
i heard about the rule that 0.8xKVA = KW
so off a 60kva genny, you should draw a maximum of 48kw as far as i know!
#5 Hal Smith
Hal Smith
  • 2280 posts
  • OKC area
Posted 13 July 2007 - 02:05 PM
If you're running tungsten only and don't try to turn everything on at once then a generator with a rating equal to the load should be okay. If you're running a lot of HMI with magnetic ballasts then it probably is a good idea to derate the generator to 80% or so. This is all about the load's power factor rating, that's basically an indication of how much power is wasted (not exactly but do you REALLY want to get into a discussion of Complex Algebra as it relates to Alternating Current?).
Generators are like heavy duty trucks, the good ones will pull their maximum load for days without any problem. I personally rent generators from Aggreko whenever possible. If I was in one of the production centers like NY or LA I'd probably have alternate sources but out here in the Heartland they're the only generator company I trust.
