Sun set effect
9 replies to this topic
#1 Zamir Merali
Zamir Merali
  • 185 posts
Posted 17 July 2007 - 11:49 PM
Hi
I need to insert a realistic, magnificent sunset behind an actor on a locked off shot in my upcoming movie. Has anybody had any experience with computer generated sunsets? Would it be better to completely computer generate the sunset or should I find a sunset and composite that behind the actor? The effect should look alot like the shot in ET where the kids fly past the sunset in silouhette. Thanks
#2 CJ Henke III
CJ Henke III
  • 41 posts
Posted 18 July 2007 - 06:06 PM
Hi
There is a number of ways to film this, personally I have my own methods that differ each time based on the shot.
If you want you can film it on a bright cloudy day, and add it all in via After Effects.
watch this and see how easy it is to replace the sky.
http://videocopilot....dvsky/index.htm
#3 Zamir Merali
Zamir Merali
  • 185 posts
Posted 22 July 2007 - 12:24 PM
But where could I get the sunset/sunball footage to composite behind the actor. Are there any good stock footage suppliers that could supply a piece of footage like that. Thanks
#4 Andre LeBlanc
Andre LeBlanc
  • 51 posts
Posted 22 July 2007 - 04:13 PM
If you're looking for stock, you could always try gettyimages: www.gettyimages.com
#5 Scott Fritzshall
Scott Fritzshall
  • 584 posts
Posted 23 July 2007 - 09:36 AM
Maybe take a look at Vue 6 Infinite if you decide to go the CG route. You can get some pretty neat, fairly realistic looking stuff with it, at the cost of huge render times.
#6 Chris Keth
Posted 24 July 2007 - 07:59 PM
Why don't you just shoot it? You can make a pretty ordinary sunset look pretty amazing with some careful filter application.
#7 Zamir Merali
Zamir Merali
  • 185 posts
Posted 24 July 2007 - 09:21 PM
How could I shoot an ordinary sunset to make it look gigantic. I'm looking to have the sun turn into a ball that is pretty big, but still looks natural. I tried some tests with my digital slr and overexposing doesn't get the desired effect. For the actual shot I am using 50d 16mm film. Thankyou.
#8 Leo Anthony Vale
Leo Anthony Vale
  • 2010 posts
  • Pittsburgh PA
Posted 25 July 2007 - 02:48 PM
Use a rather long lens. The sun is 1/2 degree in diameter.
Then you'll need a long lens for the foreground element so the two match.
#9 Will Earl
Will Earl
  • 385 posts
  • Wellington, NZ
Posted 25 July 2007 - 05:08 PM
Depending on how much compositing or matte painting work is going here, it's not a requirement that the lenses match. Obviously the sky plate needs to match the FG (if the FG is being shot separate on a greenscreen), but if the effect is for a giant sun to be composited into the shot, then shooting the sun on a longer lens to fill frame and then rescaling it to the fit the shot isn't going to a problem.
#10 Josh Brokenbourgh
Josh Brokenbourgh
  • 55 posts
  • Portland, Oregon
Posted 25 July 2007 - 05:51 PM
http://www.artbeats....php?pg=1&id=239
These guys are good. I have this set. You could combine the after effects idea with stock footage. Just depends on what look you want.
How much of the frame you want the sun to take up?
I would shoot it then combine if you have time. Original is much mo' better
