far overhead shot
#1 Fulgencio Martinez
Fulgencio Martinez
  • 164 posts
Posted 27 July 2007 - 09:13 AM
hi,
I need to shoot a very far overhead shot.
All i have used before is a scorpio head with a 13m arm.
I feel for this shoot it might not be enought as i need to set the camera at least at 10 meters high and completely perpendicular to the ground.
I´ve seen systems based on wires for football match.
Do you know this systems?
Anyone has experience with them?
is there any other options for this shot?
thanks
#2 Jonathan Bowerbank
Jonathan Bowerbank
  • 2815 posts
Posted 27 July 2007 - 11:38 AM
It's called Skycam. Mainly used for sports but it has been used in a few films. One that comes to mind is a shot from "Terminal" that starts on Tom Hanks' closeup then trucks out through a large airport lobby.
There are other cable systems that are mainly for vertical camera movements if that's all you need.
#3 Brad Grimmett
Brad Grimmett
  • 2660 posts
  • Steadicam Operator
Posted 27 July 2007 - 01:11 PM
If you don't need to move the camera during the shot you could use a cherry picker. Here's an example of a very high overhead shot that rises up that was done using a pulley system with a steadicam operator attached. I'm sure it could be done sans steadicam.
http://www.steadisho....cfm?shotID=267
#4 Fulgencio Martinez
Fulgencio Martinez
  • 164 posts
Posted 28 July 2007 - 07:10 AM
Really i don´t need to move the camera.
Just set it vertical and frame, but no movement
#5 Brad Grimmett
Brad Grimmett
  • 2660 posts
Posted 28 July 2007 - 04:09 PM
A Condor or cherry picker will do the job.
