Bolex 480 battery
#1 Pete Von Tews
Pete Von Tews
  • 89 posts
  • Concord CA USA
Posted 28 July 2007 - 04:47 AM
Hi everyone, I have a Bolex 480 super 8mm camera that I'm trying to bring back to life, the problem is that the metal in the battery compartment is so corroded that I'm not sure how to rebuid the the battery contacts. Does anyone here use a bolex super 8 that uses 5 AA batteries that come in a little "cartridge"? I need to rebuild the metal contacts on the "cartridge" lid.
thanks!
#2 Alessandro Machi
Alessandro Machi
  • 3323 posts
  • California
Posted 29 July 2007 - 06:40 AM
thanks!
I have used solder with limited success. The problem is the plastic starts to melt as the solder gets hots. Perhaps if you added a very small piece of aluminum foil the solder will stick quicker and easier, just make sure you don't creat a "short" situation.
#3 Pete Von Tews
Pete Von Tews
  • 89 posts
  • Concord CA USA
Posted 29 July 2007 - 07:17 PM
I discovered that the Bolex 480 has an external power jack. I plugged in a 300MA power source and the camera runs! Now I just have find how much volts it needs. There are 5 1.5v AA batteries in the "battery pack" so that's 7.5volts, but I have a feeling one AA battery might be for the light meter. The camera has a footage meter, so I'll run it at 24FPS at different voltages and see how long it takes to go through 50 feet on each voltage. I think that should help me indicate the right voltage I hope.
Thanks!
#4 Alessandro Machi
Alessandro Machi
  • 3323 posts
  • California
Posted 30 July 2007 - 11:19 PM
Thanks!
Not necessarily. Some cameras have regulators that don't allow the speed to change even if you change the voltage, however you could burn out some other component. 7.5 is a very logical guess if the camera has 5 batteries in the handle.
#5 Pete Von Tews
Pete Von Tews
  • 89 posts
  • Concord CA USA
Posted 31 July 2007 - 09:54 PM
Hi Alessandro!
Yes, I agree about the internal voltage regulator!
Here are results of my tests +/- 1 seconds
These were timed using the built in footage meter. I start the timer when I start the camera, then stop the timer when the footage meter reaches past 50feet and makes a distinctive "click" sound.
BOLEX 480
300 MA 110 volt wall adapter with selectable voltage
VOLTS-----FPS---------TIME---------FRAMES
4.5_______24_______2:40_______3840
6.0_______24_______2:34_______3696
7.5_______24_______2:35_______3720
9.0_______24_______2:37_______3768
4.5_______40_______2:05_______5000
6.0_______40_______1:35_______3800
7.5_______40_______1:23_______3320
9.0_______40_______1:12_______2880
These numbers should be compared to this camera running off a fresh set of 5 AA battteries and see which number is closest, but I think 7.5 volts would probably be better than 6volts, for a added boost of power.
I did the total frames number just for a reason to use my vintage calculator =)
