New 28-70mm & 80-200mm T2.8 zoom lenses
27 replies to this topic
#1 Max Jacoby
Max Jacoby
  • 2955 posts
Posted 05 August 2007 - 06:00 AM
For 'The Bourne Ultimatum' Arri Munich rehoused 2 Nikon digital zoom lenses: a 28-70mm and a 80-200mm. Both are T2.8 throughout. There is more sets coming. I haven't spoken to Arri directely yet, but it seems the main advantage of these lenses is their light weight.
I'd be curious how the wider lens compares optically to the 28-76mm T2.6 Optimo, which is itself a lightweight lens.
#2 Ruairi Robinson
Ruairi Robinson
  • 279 posts
Posted 08 August 2007 - 05:12 PM
Hmm... interesting to know... do you imagine these lenses unmodified might be a decent option for use with the Red camera? Are these Nikkor/F-mount pre-modification? Makes me a little less snooty about considering SLR lenses!
Do you know which models they used? this one is f2.8 not T2.8:
http://www.bhphotovi..._AF_S_Zoom.html
there's an article about the Bourne thing (including the same info about nikon lenses used) here
http://www.cameragui...htm~top.main_hp
(assuming thats not where you read it in the first place)
says 80% of first unit shooting was done with these two lenses...
Cheers for the info,
R.
#3 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 09 August 2007 - 03:59 AM
Hi Ruairi,
It's quite likely that lenses from several zooms get used to produce a really good one.
Stephen
#4 Brian Drysdale
  • 5196 posts
Posted 09 August 2007 - 04:00 AM
The article doesn't say how much modification (if any) of the mechanics of the Nikon zooms was undertaken by Arri. This is the weakest part of stills lenses compared to cine lenses and would a even bigger issue with SLR zooms lenses compared to SLR prime lenses.
#5 David Auner aac
David Auner aac
  • 1117 posts
Posted 09 August 2007 - 05:03 AM
I wonder what the DP meant by "digital" Nikon lenses. The only 28-70 and 80-200 2.8s I know are made for full frame 35mm still film. As for their being light I'm even more curious. How heavy is a typical zoom for 35mm cine with a PL mount? Still film wise I would call both of these lenses rather heavy pieces of glass.
Having used both lenses myself (if he indeed meant the AF-S 80-200 2.8 and the AF-S 28-70 2.8) these are excellent lenses for still photography. Check out this site for information on Nikon lenses. It the best you can find!
http://www.photosynt...pecs.html#70-xx
Regards, Dave
#6 Max Jacoby
Max Jacoby
  • 2955 posts
Posted 09 August 2007 - 05:36 AM
They are made for 35mm size sensors so they are telecentric I'd guess.
#7 Mitch Gross
Mitch Gross
  • 2873 posts
Posted 09 August 2007 - 01:31 PM
Telecentric would mean glass that is designed to focus properly for a 3-chip camera using a prismatic beam splitter. That's what video B4 mount lenses are.
#8 Max Jacoby
Max Jacoby
  • 2955 posts
Posted 09 August 2007 - 04:49 PM
I was under the impression that telecentric meant that the rays of light hit the film, respectively the sensor at a 90 degree angle (i.e straight). If they came at an angle it would still be alright for film, but with a sensor it could lead to loss of exposure. At least that is how I've seen the word 'telecentric' used, for instance on flyer about the new Hawk V-plus lenses, which are obviously not designed for 3-chip cameras.
#9 Mitch Gross
Mitch Gross
  • 2873 posts
Posted 09 August 2007 - 05:08 PM
Hmmn. I've seen it specifically used the way I describe. I'll look into it as it may be a siliar term. How horribly confusing.
#10 Max Jacoby
Max Jacoby
  • 2955 posts
Posted 09 August 2007 - 05:26 PM
I did a quick google for the term and it seems that telecentric means that the rays are parallel to the optical axis.
What is Telecentricity?
By Jim Michalski
Telecentricity is a special property of certain multi-element lens designs in which the chief rays for all points across the object or image are collimated. For example, telecentricity occurs when the chief rays are parallel to the optical axis, in object and/or image space. Another way of describing telecentricity is to state that the entrance pupil and/or exit pupil of the system is located at infinity
http://www.edmundopt...m?articleid=261
This is what Wikipedia has to say (not always the best source, I know!)
A telecentric lens is a compound lens with an unusual property concerning its geometry of image-forming rays. There are two main types, each with its own use:
A lens that is object space telecentric is usually employed for machine vision systems in order to achieve dimensional and geometric invariance of images within a range of different distances from the lens and across the whole field of view.
A lens that is image space telecentric is used with image sensors that do not tolerate a wide range of angles of incidence. For example, a 3-CCD color beamsplitter prism assembly works best with a telecentric lens, and many digital image sensors have a minimum of color crosstalk and shading problems when used with telecentric lenses.
A lens is called double telecentric if it is telecentric on both sides.
The technical property that distinguishes telecentric lenses is that the chief rays, that is the rays through the center of the entrance or exit pupil, are all parallel to the optical axis, on one or both sides of the lens, no matter what part of the image space or object space they go through.
#11 Mitch Gross
Mitch Gross
  • 2873 posts
Posted 10 August 2007 - 12:52 AM
You're most definitely correct and now I'm going to be up very late trying to recall the correct term. Vidi-centric perhaps? There is a specific word to describe a lens that is designed to correct for the shift in wavelength depth of a 3-chip prism block. If anyone can relieve my misery I'd appreciate it as this escapes me at the moment.
Sorry to hijack the thread from what sounds like some very interesting optics.
#12 David Auner aac
David Auner aac
  • 1117 posts
Posted 10 August 2007 - 01:11 AM
Still, it is interesting to note that IIRC both of these lenses were around a while before Nikon had their first DSLR out (the D1 in 1999). SO doubt that they had these designed to be used on digital cameras.
Cheers, Dave
#13 Max Jacoby
Max Jacoby
  • 2955 posts
Posted 10 August 2007 - 05:48 AM
I'd first check if they hold focus when zooming, because many (most?) stills zoom lenses do not.
#14 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 10 August 2007 - 07:30 AM
Hi Max,
I always assumed that if high quality still camera zoom lenses were collimated they might zoom OK, they are generally not that wide so I think it's possible.
Stephen
#15 Hal Smith
Hal Smith
  • 2280 posts
  • OKC area
Posted 10 August 2007 - 08:07 AM
Cheers, Dave
That wouldn't surprise me in the least. Nikon's marketing people have probably fallen victim to the disease of "digitalitis" where calling something "digital" is believed to give it magic sales properties.
#16 Mitch Gross
Mitch Gross
  • 2873 posts
Posted 10 August 2007 - 12:58 PM
Back to "telecentric."
Max is correct, and it turns out we're talking about the same thing. For 3-chip cameras the lens must be telecentric as Max described so that the light hits the dichroic filters for color separation at the correct angle. As a different issue to this the image planes for the three primary colors are at slightly different depths due to their differing frequencies and the lens design must account for this. I thought that this second aspect was included in the term "telecentric" but it is not, and there is no particular single word definition for this.
And now back to your regularly scheduled thread.
#17 Hal Smith
Hal Smith
  • 2280 posts
  • OKC area
Posted 10 August 2007 - 02:31 PM
Further hijacking the thread: Are you certain about that? Why wouldn't one just adjust the backfocus for each sensor independently to compensate for any optical path differences?
Inquiring Minds Want to Know.
#18 David Auner aac
David Auner aac
  • 1117 posts
Posted 10 August 2007 - 02:49 PM
Hi Hal,
hehe, that might be very true, but so far I haven't heard of any case of this very contagious disease at Nikon's HQ.
If you refer to the article, the DP said something about "digital Nikon lenses". As a side note, I really enjoy the fact that you can take a 35-40 year old Nikon lens and mount it on a brand new digital D2x. Actually I have just bought a 135 and a 180/2.8. I will use these with a DOF adapter (Brevis) on my video camera and (hopefully soon) on my new Eclair NPR.
Cheers, Dave
#19 Mitch Gross
Mitch Gross
  • 2873 posts
Posted 10 August 2007 - 02:57 PM
Forty odd years of video lens technology are pretty well ingrained. This is the way it's done because this is the way it's done.
#20 David Auner aac
David Auner aac
  • 1117 posts
Posted 10 August 2007 - 03:02 PM
Hi folks,
being complete ignorant of the hands on things in 35mm cinematography, how heavy is a normal T2.8 zoom in that range with PL mount? The Nikons mentioned weigh around 1000 and 1300 grams respectively. The article mentioned them being lightweight, so I wonder...
Cheers, Dave
