5600K Lighting Gel.
#1 Matthew Buick
Matthew Buick
  • 2345 posts
  • Newcastle upon Tyne, UK.
Posted 05 August 2007 - 02:38 PM
Can anyone tell me which gel would be used to convert 3200K Tungsten Light to 5600K?
Thanks. ;)
#2 Chris Keth
Posted 05 August 2007 - 05:27 PM
Thanks. ;)
Full CTB (Color Temperature Blue). Beware, though, it cuts a lot of light: 1 and 2/3 stops.
#3 Xavier Plaza
Xavier Plaza
  • 288 posts
  • Guayaquil - Ecuador
Posted 07 August 2007 - 11:47 AM
As Chris say Full CTB is what you need. Be carfull because when you use a lot this filters they loose the original color. When you use film is better use new filters
#4 Ralph Keyser
Ralph Keyser
  • 120 posts
Posted 07 August 2007 - 05:55 PM
It's Lee #201 and Rosco #3202.
In many cases, you may be able to use 1/2 CTB as a compromise to get part of the way there without loosing so much light.
#5 Matthew Buick
Matthew Buick
  • 2345 posts
Posted 09 August 2007 - 01:31 PM
Thanks so much, all. ;)
When purchasing will I have to specify dimensions, or is there somewhere I can buy a pre-cut piece?
#6 Jonathan Bowerbank
Jonathan Bowerbank
  • 2815 posts
Posted 09 August 2007 - 01:40 PM
They generally come in 21" x 24" sheets at your local expendables & film equipment shop
#7 Matthew Buick
Matthew Buick
  • 2345 posts
Posted 09 August 2007 - 02:00 PM
Thanks. I'll order some from an online store.
As you're here, Jonathan, this seems the perfect time to ask. Is it possible to gel a chinese lantern. I'm going to buy one and was wondering.
Thanks.
#8 Jonathan Bowerbank
Jonathan Bowerbank
  • 2815 posts
Posted 09 August 2007 - 06:25 PM
Yes.
It's a bit tricky since the gels aren't made to fit flush against the walls of a spherical object, so you'll have to deal with some portions of ungelled/color manipulated light leaking about. But I used a 1/2 CTB on my recent shoot just to cool down the color temp a smidge, and it worked fine.
#9 Michael Collier
Michael Collier
  • 1262 posts
Posted 09 August 2007 - 08:24 PM
To gell a china lantern, I have rolled CTB into a cylinder and taped it with roscor (I believe) heat sheild tape (which is clear and heat resistent) and fit that cylinder over the cage that holds the light. It usually works well. Only the top and bottom will leak unfiltered light, which can be flagged with blackwrap without loosing much light.
