remote switch
#1 rob spence
rob spence
  • 427 posts
  • Beaconsfield
Posted 06 August 2007 - 04:48 AM
Hi
I need to make a remote switch to trigger an aaton...for use on car rigs etc. Consisting of an electric cable and a push switch.
Does anyone know what rating the electric cable should be and how long the cable could be?
best
rob spence
#2 David Auner aac
David Auner aac
  • 1117 posts
Posted 06 August 2007 - 09:13 AM
Hi Rob,
I can't help you specifically with the Aaton, but I am assuming that the amount of power running through that cable won't be large. Normally cable used for switches is really thin, from 0,14 to 0,22 square mm. If you take larger diameter cable, say 1 sq. mm you should be more than ok. As for length, the thicker the cable, the lower it's resistance. So you should choose larger cables for longer runs. Can you be any more specific about the power system of the Aaton. 12V?
Regards, Dave
#3 rob spence
rob spence
  • 427 posts
  • Beaconsfield
Posted 06 August 2007 - 12:08 PM
Hi Rob,
Regards, Dave
thanks Dave, the aaton is 12 volt and I would like a 15 foot cable
best
rob spence
#4 Mitch Gross
Mitch Gross
  • 2873 posts
Posted 06 August 2007 - 04:14 PM
Rob, we have nice pre-made remote cable switches for the Aaton sitting on the shelf, both in sales and rental. You could save yourself the trouble by getting it from us if you wish.
