CP16- R film take up spool problem...
7 replies to this topic
#1 gareth Mcg
gareth Mcg
  • Australia
Posted 06 August 2007 - 11:15 AM
Hi everyone
Ive just got my hands on a CP16-R camera...their are a few issues with the camera that I'm trying to sort out. But my main concern is that the take up spool doesn't take up the film fast enough and the film just spirals out of control after 2/3 seconds.
I will see if I can test another mag first! but can I tighten the take up spool?
Problem info.
The Film is loaded correctly and runs perfectly through the camera until it re-enters the mag. The Mag is locked in position and the take up spool does rotate at the same speed as the leader spool I have checked this by marking both of the outer spool cores on the mag and watched them rotate simultaneously. (Sorry for not using correct terms)
Battery is also fully charged and the camera/mag looks extremely used - probably had a hard life.
any thought?
#2 Mike Rizos
Mike Rizos
  • 330 posts
Posted 06 August 2007 - 03:09 PM
The feed and take up spools should not spin at the same rate. As film is displaced the take up spool should spin faster than the feed at the begining of the roll, about the same in the middle of the roll, and slower toward the end.
All else being correct the problem is not enough tension on the take up spool.
The remedies:
1) Replace magazine drive belt.
2) Adjust clutch drive belt tension (this is the internal herring bone belt, you need to open the camera for this).
3) Replace clutch drive belt.
#3 Herb Montes
Herb Montes
  • 225 posts
  • Gulf Coast of Texas
Posted 06 August 2007 - 08:04 PM
When I first got my CP-16R I tested it by running leader through it with the camera door and magazine open. I watched everything as it ran to make sure the film went through without any problems. Now I'm ready to shoot real film with it.
#4 gareth Mcg
gareth Mcg
  • Australia
Posted 06 August 2007 - 08:28 PM
Thanks Mike, very helpful.
Ill study the speed of the take up spool. It did cross my mind that it should be faster - makes sense ;).
cheers
#5 Matt Pacini
Matt Pacini
  • 1246 posts
Posted 13 August 2007 - 04:59 PM
One thing I ended up having to replace in my CP-16R, was that clutch mechanism that drives the takeup.
It's not uncommon. I got a rebuilt one from Paul Hillman at Visual Products.
I had the same problem. It also caused me to eat a fishbone belt, so you may have to get one of those as well, because the uneven speeds/tension causes it to chew off the nubs on the fishbone belt.
Look inside your camera, and see if there are little tiny blue bits floating around in the bottom of the felt.
They may still be in the other side (inside the camera), so this doesn't mean you DON'T have that problem, but if you see those things, absolutely get a new belt, as well as the clutch.
Call Paul Hillman, he'll know exactly what to do.
Great guy, great camera tech, totally honest.
Matt Pacini
#6 Robert Hughes
Robert Hughes
  • 873 posts
  • Sound Department
  • Minneapolis
Posted 14 August 2007 - 09:34 AM
Yep that fishbone belt disintigrates after a couple decades, I got a replacement from Whitehouse AV. The clutch may need to be adjusted to a torque spec; check with a repair pro to find out. Also, you might consider using a 3" takeup core if you're shooting 100' or 200' loads; I don't think a 400' load will fit.
Edited by Robert Hughes, 14 August 2007 - 09:36 AM.
#7 Robert Hughes
Robert Hughes
  • 873 posts
  • Sound Department
  • Minneapolis
Posted 14 August 2007 - 09:37 AM
Yeah, me too. I always use videotape for testing... :rolleyes:
#8 Herb Montes
Herb Montes
  • 225 posts
Posted 14 August 2007 - 12:51 PM
And I always tested a new VCR by running Kodachrome through it first. :lol:
