dxc d50 problem
#1 kishor karki
kishor karki
  • 2 posts
Posted 09 August 2007 - 02:44 PM
hi, lately i came up with a problem while shooting with sony dxc d50 camera.only the red channel was recorded and the output on the monitor was same.plz anyone knows what the problem is. and any solution?
#2 Michael Nash
Michael Nash
  • 3330 posts
  • Pasadena, CA
Posted 14 August 2007 - 01:13 AM
Could be a lot of different things. Did you try viewing the output from the camera head, vs. the recorder back? It could be a connection problem between the head and the dockable recorder. Has the camera suffered any hard bumps or shakes recently?
Did the image look odd in the viewfinder? If it did, then the image is going awry in the signal processing. If it didn't, the problem is somewhere downstream from there. You can troubleshoot most electronic problems by checking from one end of the signal path and working your way toward the other; doesn't matter which end you start from. I suspect the camera needs to go in for service.
