(for instance)...lighting. !?
7 replies to this topic
#1 ross e lea
ross e lea
  • 55 posts
Posted 11 August 2007 - 12:55 AM
hypothetical scene:
2 pool balls are sitting on a table. room is completely black. there is one
par can spotting from one side on one ball. shooting @ 24fps with lets
say.....250Tungsten fuji film.
meter readings:
f16 on table in brightest point of spotlight
f8 on well lit pool ball
f4 on second pool ball not lit so well
OK...the objective here is to get the nicest, evened out shoot possible where
the well lit ball is the focal point. I would think you light for f8 because thats
what your best light to be representing, right?
or because of the DARK context here....would you push the f-stop closer to
f5.6?
any opinions on dark stuff like this, because whenever I light for dark things
with my 16mm camera, it seems to always turn out a little greyish or
overexposed maybe.
REALLY, IN A NUTSHELL....I'M JUST LOOKING FOR LIGHTING
TECHNIQUES. YOUR USUAL RITUAL FOR FINDING THE PERFECT EXPOSURE!?
thnks
#2 Mario C. Jackson
Mario C. Jackson
  • 138 posts
Posted 11 August 2007 - 01:50 AM
Ross
It all depends on what you are exposing for. Remember when you are trying to get a low level of light it isn't necessarily how dark something is but rather how much difference between the brightest and darkest point in the frame. For example if you expose one ball at T8 and the table itself at T2.8 the ball will definetley stand out because it is several stops brighter than the table. In theory your eyes go to the brightest part or thing in the frame first.
Hoper this helps
Mario Concepcion Jackson
#3 Jonathan Bowerbank
Jonathan Bowerbank
  • 2815 posts
Posted 11 August 2007 - 03:06 AM
If that par can is blasting in at an f/16, you're gonna get quite a bit of spill, depending on the surface it's shining onto. So be aware of how much spill you're effectively creating by having a light that hot.
#4 ross e lea
ross e lea
  • 55 posts
Posted 13 August 2007 - 08:28 PM
helpful. :)
still seems like my shooting is always slightly hazy or
overexposed or something. maybe I should be lighting
my scenes brighter in general to get all areas up to
where I can just pull down the exposure in post.
should I have chose 250T for the poolball context?
as long as I light properly for the stock....shouldnt
I get less grain by choosing the 250?
or is the 500stocks really meant for those dark scenes?
keep it comin yall
very helpful
#5 Jonathan Bowerbank
Jonathan Bowerbank
  • 2815 posts
Posted 13 August 2007 - 08:36 PM
It also depends on the color timing. It could be that your timer is bringing up the blacks and timing the print for your underexposed portions instead, so you have more detail in the shadows, hence the grayer image. Are you shooting an 18% grey card at the head of the reel so the timer knows what your key is at?
It also helps to over expose a bit, perhaps by 2/3 a stop, so you have a denser negative in general and less grain.
For example, if you're shooting 500T stock, you'd set your meter for 320 ASA to get a healthy general over exposure.
Edited by Jonathan Bowerbank, 13 August 2007 - 08:38 PM.
#6 ross e lea
ross e lea
  • 55 posts
Posted 13 August 2007 - 09:04 PM
helpful, thanks. :)
I just tell them best-light. shouldnt they realize whats best for the exposure made?
isnt an exposed negative an exposed negative?
#7 Michael Nash
Michael Nash
  • 3330 posts
  • Pasadena, CA
Posted 13 August 2007 - 09:55 PM
helpful, thanks. :)
Not if you tell them "best light" -- that means that they determine the proper transfer or printer light levels for the image. They could be brightening up the image to compensate for the darker content, like Jonathan suggests.
Ask for a "one light" print or transfer if you want to see the exposures on your negative "warts and all."
#8 Jonathan Bowerbank
Jonathan Bowerbank
  • 2815 posts
Posted 13 August 2007 - 11:33 PM
This is something color timers hate to hear, incidentally. They don't know what you want, so you can't expect to be happy with what they give you. Like I said, unless you have a grey card at the head, they're not going to know exactly what you want.
