HVX200 with 16GB P2 Cards
11 replies to this topic
#1 Jasper Granderath
Jasper Granderath
  • 24 posts
Posted 11 August 2007 - 05:46 AM
Hey folks,
i will shoot a short in two weeks with the HVX200. I would like to record my shots on two 16GB P2 Cards, that i can get for free. As a rebate. Now i've heard several times that the first HVXs Panasonic sold, are not able to handle with the 16GB Cards. So my questions: Is this true? Had anyone here problems with these cards? Is it true that this problem is easy to solve with a firmware update for the HVX?
Thanks for helping me.
Cheers,
Jasper
#2 Michael LaVoie
Michael LaVoie
  • 749 posts
Posted 11 August 2007 - 06:35 AM
you have to update the firmware in the camera. It's simple. All you need is an SD card. You download the update from https://eww.pavc.pan...c.co.jp/pro-av/ and open that (vsi4598g folder ), place the (private) folder on the SD card and then load that in the camera and there are further instructions on how to start the update process. After that it's all automatic.
#3 Jasper Granderath
Jasper Granderath
  • 24 posts
Posted 12 August 2007 - 07:19 AM
Hi Michael,
thanks for your reply. That was the reply i was hoping for.
Cheers,
Jasper
#4 Michael Nash
Michael Nash
  • 3330 posts
  • Pasadena, CA
Posted 27 September 2007 - 11:26 PM
Are the 4GB cards still useable in the camera once it's had the firmware update? Is there any issue using both 4GB and 16BG cards in FCP?
#5 Adamo P Cultraro
Adamo P Cultraro
  • 157 posts
Posted 27 September 2007 - 11:38 PM
I have a 4 and a 16 after the firmware update. Works fine. No ideas about FCP thought - I use Vegas. Even so, I just dump the card on the drive. My NLE has no contact with the card; I'm assuming the same for most other people.
#6 Tio Poreamo
Tio Poreamo
  • 6 posts
Posted 04 October 2007 - 09:28 PM
Can I ask from where are you buying the HVX200 where they give you two 16GB P2 card?
I am planing to get the same setup + steady cam system...etc. and I am trying to find the best deal.
Thanx
Tio
#7 Adamo P Cultraro
Adamo P Cultraro
  • 157 posts
Posted 04 October 2007 - 09:58 PM
You have to buy the camera and the cards separately. As far as I know the promotion (1 free P2 card) has ended.
#8 dullataj
dullataj
  • 19 posts
Posted 19 December 2007 - 05:58 AM
Hi How's different between 4 GB and 16GB Cards?
The software.....if you had old software driver which can read the data of 4 GB Card well....but you can not to read the data in 16GB Card.......please you do not worry...please come to upload free software driver.....then your computer can read all data in 4, 8, 16 GB...
dullataj@hotmail.com
Yoi Camera Corner Thailand
#9 dullataj
dullataj
  • 19 posts
Posted 19 December 2007 - 06:02 AM
Final Cut PRO must use Final Cut PRO 5.02 or Later....it can support with HD File....But please you check with your computer that did you install some programs inside 1) P2 Driver 2)P2 Viewer....
#10 Bill Totolo
Bill Totolo
  • 700 posts
Posted 19 December 2007 - 11:44 AM
Be aware that a lot of people are having an audio issue using the 16G cards in slot 1.
The workaround is to simply use slot 2. This is only with the 16G cards.
#11 Tim O'Connor
Tim O'Connor
  • 860 posts
  • Boston, Massachusetts
Posted 20 December 2007 - 12:45 AM
WOW. Glad I read this. I hadn't heard anything but I'm going to ask around. In the meantime,
I haven't been needing to hotswap 16GB cards, so it's slot 2.
#12 dullataj
dullataj
  • 19 posts
Posted 20 December 2007 - 04:30 AM
Hi man.....I have 2 of 16GB P2 Cards now and it's work well no problem with my HVX 202EN....
Yoi CC
