Shooting PAL / 60HZ vs 59.94 HZ
#1 david_morrison
david_morrison
  • 7 posts
Posted 15 August 2007 - 12:15 AM
Hey,
I'm in Europe shooting some Microsoft commercials, we are using the Varicam / PAL. and the question has come up about the HZ rate. my understanding is at 25fps we should be shooting at 60 HZ. Is this correct? Do you have any other insights or feedback?
I appreciate it.
David
davidrmorrison.com
#2 Nick Mulder
Nick Mulder
  • 1023 posts
  • Auckland, New Zealand
Posted 15 August 2007 - 12:45 AM
Dont quite get your question...
but:
European power is 50Hz so shoot at 25fps
#3 david_morrison
david_morrison
  • 7 posts
Posted 15 August 2007 - 04:23 AM
but:
#4 david_morrison
david_morrison
  • 7 posts
Posted 15 August 2007 - 04:25 AM
The camera can be set at 60HZ or 59.94HZ. I just want to make sure that 60HZ is the right setting. I am shooting at 25fps.
what would happen if I shot at 59.94?
#5 John Ealer
John Ealer
  • 187 posts
Posted 15 August 2007 - 08:36 AM
David -
Since your end product is PAL, which is a pure 50i, then you are correct in that you'd want the varicam set to 60Hz mode. If you set the camera to 59.94, then your 25fps footage would actually be 24.975, which could cause you a headache in post.
J
#6 John Sprung
John Sprung
  • 4635 posts
Posted 15 August 2007 - 01:19 PM
Hey,
I appreciate it.
David
davidrmorrison.com
Correct, the PAL/SECAM world is strictly "point zero zero". It's only when you need to be in sync with NTSC that you use "point nine something".
