Cinematography terminoology in Spanish (Part 2)
#1 Gabriela Castanon
Gabriela Castanon
Posted 16 August 2007 - 01:46 AM
Hola everyone,
It's me again. Please can you also give me the Spanish and/or French terminoology fro the following:
1. Pan
2. Tilt
3. Crab (left/right/forward etc)
4. Crane (up/down)
5. Dolly, and dolly up/down
6. Wide-angle lens
5. Telephoto lens
6. Neutral Density
7. Dolly tracks
Thanks.
Andrea
#2 Jonathan Bowerbank
Jonathan Bowerbank
  • 2815 posts
Posted 16 August 2007 - 02:22 AM
oooo, quite a challenge. I'm just gonna guess some of'em, because I'm pretty sure they just translate directly over. And yes, I speak Spanish :)
In the meantime, looky:
http://www.amazon.co...o/dp/0943288037
http://www.amazon.co...d...9021&sr=1-6
1. Pan - Voltar
2. Tilt - Inclinar
3. Crab (left/right/forward etc) - Cangrejo
4. Crane (up/down) - Grua (Subir/Bajar)
5. Dolly, and dolly up/down - Carretilla?
6. Wide-angle lens - Lente Ancho
5. Telephoto lens - Lente Telefotographico (just telefoto?)
6. Neutral Density - Densidad Neutral
7. Dolly tracks - Carriles
Edited by Jonathan Bowerbank, 16 August 2007 - 02:24 AM.
#3 Laurent Andrieux
Laurent Andrieux
  • 1527 posts
  • France
Posted 16 August 2007 - 06:49 AM
French terminoology
1. Pan : panoramique horizontal
2. Tilt : panoramique vertical
3. Crab (left/right/forward etc) rouler en crabe (à gauche à droite, en avant, en arrière)
4. Crane (up/down) : montée / descente de grue
5. Dolly, and dolly up/down : rouler, montée / descente de colonne
6. Wide-angle lens : grand angle
5. Telephoto lens : téléobjectif
6. Neutral Density : densité neutre
7. Dolly tracks : travelling
You're welcome
#4 Xavier Plaza
Xavier Plaza
  • 288 posts
  • Guayaquil - Ecuador
Posted 16 August 2007 - 11:48 AM
Hi Andrea once again all depends where you shoot. If you shoot in Spain there they use a different translation of this words, the same happens in Argentina. I prefer use the words in english an then translate to spanish to avoid any misunderstood. Jonathan i agree with you unless the first and the second words, the others are ok, just one more thing you can use the same name dolly in spanish or english the people would understand...
Best
Xavier Plaza
Just in case you speak spanish:
Hola Andrea una vez mas depende el pais donde filmes. Si tu filmas en España o en Argentina ellos utilizan distintas traducciones para las mismas palabras depende del sector donde filmes. Yo personalmente prefiero decir o usar los terminos en ingles y de ahi decirlos en espanol para evitar mal entendidos y hasta en mi mismo pais cuando cambio de zonas o regiones, ya los terminos cambian, para que tengas una idea. Espero que esto te sirva
Saludos
xavier plaza
1. Pan Paneo
2. Tilt Picado o Contra Picado
3. Crab (left/right/forward etc) I don't know what are you talking...? but as Jonathan say this mean cangrejo jeje
4. Crane (up/down) Grua
5. Dolly, and dolly up/down Carro, dolli,
6. Wide-angle lens lente angular
5. Telephoto lens tele o telefoto
6. Neutral Density ND o densidad neutral
7. Dolly tracks rieles o carriles
#5 Gabriela Castanon
Gabriela Castanon
Posted 21 August 2007 - 09:47 AM
Muchisimas Gracias Xavier! Merci beaucoup a Laurent pour TA REPONSE!
You guys helped me a lot. It is SO difficult to find this terminology in even some of the best dictionaries!
Bye,
Andrea
