gaffing, under water and flash light questions
#1 Daniel Ainsworth
Daniel Ainsworth
  • 14 posts
Posted 20 August 2007 - 12:39 AM
Hello,
I will be gaffing a short film in the upcoming months and I had a few questions. There will be an underwater scene. A young girl swims to a treasure chest. Any suggestions about how to light a scene underwater, (murky water in order to see light beams). We won't have underwater lights. Besides that our package is pretty extensive.
Another shot requires a dying flashlight on a table. We wanted the flashlight to be facing open toward camera, so we can see the source flickering and dying, I have been trying to look, but do they create bulbs that flicker in such a way. Any ideas?
Thank you.
-Daniel
#2 Jonathan Bowerbank
Jonathan Bowerbank
  • 2815 posts
Posted 20 August 2007 - 01:15 AM
If Kinoflo's are in your kit, you can put those underwater, just make sure the ballast isn't near it...that would be bad.
I'm curious to hear other people's methods of creating smoke-effect like murk underwater :)
#3 Nick Mulder
Nick Mulder
  • 1023 posts
  • Auckland, New Zealand
Posted 20 August 2007 - 01:26 AM
Yip,
the type of bulb is called a 'flashlight bulb' - its the voltage that causes the flicker
#4 Daniel Ainsworth
Daniel Ainsworth
  • 14 posts
Posted 20 August 2007 - 11:33 AM
Yip,
der, forgot about that, thanks.
Kinos are included thank you as well. I didn't realize they were designed to be placed underwater? From experience if light needs to travel from above to say a 4ft shallow end of a pool, at night, would 2ks be enough, or should I be using much more. I am just unsure about how much the water will cause the light to dissipate.
I know when you shock a swimming pool with chlorine that would cause a murky look for a little bit.
Edited by Daniel Ainsworth, 20 August 2007 - 11:37 AM.
#5 Xavier Plaza
Xavier Plaza
  • 288 posts
  • Guayaquil - Ecuador
Posted 20 August 2007 - 12:22 PM
Hi Jonathan, did you say Kino's work well under water?, I didn't know that :blink: , what is the deepest depth they support...?
Thanks for the info
Xavier Plaza
