100mm lomo anamorphic from 75mm lomo anamorphic?
#1 James Steven Beverly
  • 4199 posts
  • El Paso, Texas
Posted 20 August 2007 - 03:08 AM
Sense 100mm Lomo anamorphics are a bit hard to find, can a 100mm be built from a much more common 75mm Lomo anamorphic by a Russian (or other) camera tech? Are the extenders available and how hard is this to do if it is possible? B)
#2 Max Jacoby
Max Jacoby
  • 2955 posts
Posted 20 August 2007 - 03:33 AM
Sounds awfully complicated and expensive. Arent's there any extenders (1.4x and 2x) in Russian mount that you can just add between the lens and the regular mount? They exist in PL mount. Vantage Film even have designed a 0.7 extender that works with long lenses.
#3 Olex Kalynychenko
Olex Kalynychenko
  • 868 posts
  • Dnepropetrovsk, Ukraine
Posted 21 August 2007 - 01:37 AM
The standard kit of anamorphic version of Kinor-35( and other ) cameras included 35 mm, 50 mm, 75 mm lenses. The other lenses to delivery with special order only.
That's why, 100 mm lens rare.
I think, the idea of used of extenders can be good, but, will need test.
Zoom lens 35 OPF-18-1 have extenders 1.5x and 2.1x.
This devices can be use for test at beginning.
#4 James Steven Beverly
  • 4199 posts
  • El Paso, Texas
Posted 23 August 2007 - 03:44 AM
Olex, can these zoom extenders you mentioned be fitted with the lock (camera part) from the OCT-19 mount at the front of the extender so they can be quickly attached and detached from the 75mm lens. Then when you want to use the 100mm or 150mm lens, you lock the appropriate extender onto the 75mm lens and can put the lens on the camera? Is this possible? B)
