t vs f stop
#1 Elie Kamal
Elie Kamal
  • 24 posts
  • Beirut,Lebanon
Posted 20 August 2007 - 05:16 PM
hey there,
my name is elie and i'm a student filmmaker. this is my first post so take it easy on me...hehehe
well this is a very classical and FAQ for which i haven't got any convencing answer yet.
if T stop is more accurate than F stop then why use a light meter and not a spot meter all the time?
and if my question is not very accurate would you please explain to me "in a convincing way" the difference between Mrs T and Mrs F?...
thanks a lot
regards,
Elie Kamal.
  • 20068 posts
Posted 20 August 2007 - 07:24 PM
A spot meter is a light meter -- you mean why use an incident meter instead of a spot meter. Which just depends on whether you want to measure the amount of light falling on an object (incident) or the amount of reflectance/luminence the object has (spot).
An f-stop is a physical size, the number determined by a ratio between the length of the lens and the size of the aperture. A T-stop is just an f-stop mark that has been shifted over on the barrel to compensate for any light lost as the light passes through the lens. In other words, for example, they measure the amount of light coming through the aperture that should be f/2.8 on their meter, but find it is one-third of a stop less than that, so they move the marking for "f/2.8" on the barrel so that you actually get f/2.8 out of the back end of the lens. But having adjusted the position of the f-stop mark, they can't really call it an f-stop anymore, so they call it a T-stop ("transmission" stop.)
So if your meter tells you to shoot at f/2.8, if you set the lens to T/2.8, then you'll get f/2.8 in terms of exposure. If your lens did not have T-stops, then f/2.8 on the lens may actually be slightly less in terms of exposure.
#3 Elie Kamal
Elie Kamal
  • 24 posts
  • Beirut,Lebanon
Posted 25 August 2007 - 05:20 AM
thank you David for the clarification!
#4 Adam Frisch FSF
Adam Frisch FSF
  • 2026 posts
  • Los Angeles, USA
Posted 26 August 2007 - 06:09 PM
Also, if you're new to exposure I would strongly avoid using spot meters from the beginning. They induce such varied readings (that have no real bearing) that they can confuse rather than help. Get a good incident meter and start with that - that will cover you for 99% of all shooting situations.
#5 J. Søren Viuf
J. Søren Viuf
  • 35 posts
Posted 03 September 2007 - 02:34 AM
Yeah, I just think of the t-stop as an "effective" F-stop. Meaning, the t-stop is what you are effectively getting through the lens.
JSV
