White Balancing Tungsten to Daylight
10 replies to this topic
#1 Ashley Barron
Ashley Barron
  • 115 posts
Posted 24 August 2007 - 04:33 AM
Hello,
I'm to be working on a last minute experimental shoot, with access to 3 red heads. The director wants daylight color temp, for which I know we would require 1/2 or 1/4 CTBs to be put onto the reds. At the moment we don't know if we can get the gels, and my director posed me the question 'can we just white balance to make it look cold and daylight'. My initial answer was no, but then I got curious to find out if that is possible. White balancing to Tungsten lights to achieve a daylight color temp. Don't think that's possible, considering white balancing is just telling the camera to read certain colors as white..but thought I'd pose the question anyway.
Would be great to hear any opinions!!
#2 Jonathan Bowerbank
Jonathan Bowerbank
  • 2815 posts
Posted 24 August 2007 - 11:27 AM
Yes it can be done
Place a 1/2 or 1/4 CTO gel on the lights then do a white balance, remove the gels and your light will then appear "daylight" blue in camera without any light loss due to gelling the lights.
#3 John Holland
John Holland
  • 2273 posts
  • London England
Posted 24 August 2007 - 12:25 PM
Is that right ? sounds strange to me but happy to be convinced .
#4 Jonathan Bowerbank
Jonathan Bowerbank
  • 2815 posts
Posted 24 August 2007 - 01:21 PM
Don't know what's so strange about it, it makes perfect sense and is done quite often.
Did a search for an example, and this is a good one:
http://michael-morla...ith_cc_gels.htm
#5 e gustavo petersen
e gustavo petersen
  • 128 posts
  • LA | CA | USA
Posted 24 August 2007 - 03:18 PM
If you're using a video camera you could use "white balance" to achieve the same color effect as Jonathan describes (which is a correct method).
One way is to white balance to an orange colored piece of paper. I've done this by printing colored swatches in various shades (usually five) of orange on to matte photo paper. White balance with an orange card till you find the amount of blue you're interested in.
The other method is to place a sheet (or sheets) of CTO over a white card and white balance to that. In both cases, the camera will try to correct for the warm orange color and moves the settings toward the cool blue.
If you're shooting on film, you can shoot a few seconds using either the color paper or white paper with CTO and time out the orange will give you the blue cast in your image.
You can also, if you're video camera offers it, change the internal menu settings and color your image that way.
#6 Jonathan Bowerbank
Jonathan Bowerbank
  • 2815 posts
Posted 24 August 2007 - 04:44 PM
With film, you can also shoot a grey card with an 85 or 80 filter, depending on which direction you wanna go.
#7 Ashley Barron
Ashley Barron
  • 115 posts
Posted 24 August 2007 - 09:35 PM
Thanks guys, muchly appreciated! I'll give it a go :-)
#8 Stuart Brereton
Stuart Brereton
  • 3345 posts
Posted 25 August 2007 - 03:03 PM
This would also make real daylight very blue. If you have both tungsten & daylight, then gelling your lamps is the only practical solution
#9 Matthew Buick
Matthew Buick
  • 2345 posts
  • Newcastle upon Tyne, UK.
Posted 25 August 2007 - 04:38 PM
Wouldn't it be possible to White Balance by pointing the camera in the sky (though not directly at the sun) and just use that?
#10 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 25 August 2007 - 04:43 PM
Hi Matthew,
The sky colour is not very consistent where you live, the grey will give you a normal daylight white balance!
Stephen
#11 Jonathan Bowerbank
Jonathan Bowerbank
  • 2815 posts
Posted 25 August 2007 - 09:22 PM
To achieve what? To get an accurate white balance, you need a white source. White balancing with the sky would probably leave you with an overly warm image...I imagine.
