Zeiss ultraprimes vs superspeeds at T2.8
10 replies to this topic
#1 Mr. Macgregor
Mr. Macgregor
  • 108 posts
Posted 25 August 2007 - 04:15 PM
Hi all. For a two camera shooting. Do you think i could mix shots taken with these two different sets at the same given T number? I want to shoot at T2.8 where both should perform quite well. Will i get similar resolution?
Also i am worried about the Superspeeds being quite older, in terms of barrel distortion in the wider lenses.
best,
Mac
#2 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 25 August 2007 - 04:18 PM
best,
Mac
Hi Mac,
IMO the Ultraprimes will be sharper.
Stephen
#3 Mr. Macgregor
Mr. Macgregor
  • 108 posts
Posted 25 August 2007 - 04:20 PM
Hi Mac,
Stephen
Hi Stephen! Wow, You are always online.
Do i have any other option at the superspeeds price?
Edited by Mr. Macgregor, 25 August 2007 - 04:20 PM.
#4 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 25 August 2007 - 04:24 PM
2 sets of Superspeeds!
Stephen
#5 Mr. Macgregor
Mr. Macgregor
  • 108 posts
Posted 25 August 2007 - 04:26 PM
Stephen
hahahaha.
What about barrel distorsion, will i encounter any?
#6 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 25 August 2007 - 04:35 PM
hahahaha.
Hi Mac,
They only go to an 18mm, what are you shooting?
Stephen
#7 Mr. Macgregor
Mr. Macgregor
  • 108 posts
Posted 25 August 2007 - 04:37 PM
A desert, with very straight horizontal lines:
#8 Adam Frisch FSF
Adam Frisch FSF
  • 2027 posts
  • Los Angeles, USA
Posted 26 August 2007 - 06:06 PM
Nobody will be able to see the difference unless it's an A and B test. Heck, they intercut zooms with primes all the time on features, and nobody spots that - and they're often far worse.
The Superspeeds are sharp lenses when stopped down. They fall apart a bot wide open (but in a nice, organic way), but from T2 an upwards, they're pretty hot.
#9 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 28 August 2007 - 10:21 AM
Hi Mac,
IMO the Master primes would be better for wide shots like that, for close ups of people I would prefer the Super Speeds .The difference in resolution is fairly obvious if you project the film in the cinema.
Stephen
#10 Mr. Macgregor
Mr. Macgregor
  • 108 posts
Posted 28 August 2007 - 10:41 AM
Hi Mac,
Stephen
Thanks Stephen. Master primes are away too far in price for this shooting.
The story involves some wide shots and very close ups (85-135mm).
What would you recommend then to rent?
I am thinking that i might skip film for this project and go with a RED. But since no one has ever used a red1, no one knows how cine lenses should perform (besides the S4 that Peter J and Red team have been using).
#11 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 28 August 2007 - 12:00 PM
Hi Mac,
As Adam says Superspeeds are sharp, I always use them when budgets are tight. They work OK with a P+S adapter so should work well with a RED.
Stephen
