using c-mount/arri/camflex lenses on DSLR
7 replies to this topic
#1 Justin Lovell
Justin Lovell
  • 262 posts
  • Toronto
Posted 26 August 2007 - 10:58 PM
Anyone know if there is an adapter that will allow me to use Cmount lenses on a nikon DSLR? (they don't have a full 35mm frame, so using my cmount primes or camlflex/arri mount lenses would be really cool).
#2 David Auner aac
David Auner aac
  • 1117 posts
Posted 27 August 2007 - 07:49 AM
Hi Justin,
I doubt that you could easily adapt c mount lenses. These have a very small flange focal distance (FFD), 17.526mm. The Nikon has an FFD of 46.5 mm. So you'd theoretically have to move the lens farther in, which would conflict with the mirror, but is practically impossible anyway. So you'd need some kind of relay lens.
The Arri mounts all have an FFD of 52mm so you'd just need something to move you lens a little farther away from the "film plane" to correct for that. But you'd have to use 35mm cine lenses as the usual 16mm or S16 lenses won't cover APS-C (the sensor type in Nikons current DSLRs).
IIRC there is a still camera that can be fitted with a PL mount. Will check that.
Cheers, Dave
#3 David Auner aac
David Auner aac
  • 1117 posts
Posted 27 August 2007 - 07:53 AM
Yep, here it is: Olympus Pen-PL.
Cheers, Dave
#4 Adrian Sierkowski
  • 7373 posts
Posted 27 August 2007 - 07:54 AM
I have seen the PL mount SLR for about $900, I think. It's @ the DoP Shop here
and I was beaten to giving out the link
Edited by Adrian Sierkowski, 27 August 2007 - 07:55 AM.
#5 Justin Lovell
Justin Lovell
  • 262 posts
  • Toronto
Posted 27 August 2007 - 07:30 PM
Thanks for the follow up. I was worried about the flange focal distance, didn't think it would work with Cmount lenses.
Thought it would be nice to be able to use my cmount lenses on a digital still camera...
#6 Leo Anthony Vale
Leo Anthony Vale
  • 2010 posts
  • Pittsburgh PA
Posted 28 August 2007 - 12:52 PM
I've occasionally seen on eBay an Arri=>Leica M mount adapter, which allows one to use an Arri std.mt. on a digital Leica. The ffl for Leica M is between 28 and 29mm.
The set normally has an Arri lens in the adapter.
#7 flavio filho
flavio filho
  • 247 posts
Posted 30 October 2011 - 03:29 PM
HI
i
Just saw this post from a long time ago... :P
I'm looking for ADAPTER for Arri STD LENS to NIKON F MOUNT DSLR cameras.
Does anybody knows any?
Flavio
#8 Ian Cooper
Ian Cooper
  • 469 posts
  • England
Posted 31 October 2011 - 02:56 AM
HI
i
Flavio
Try Les Bosher as the master adapter maker in the UK. If he doesn't already do what you want, then assuming it's possible he'll be able to do one-off specials as well.
