Frame stabilization in Post
#1 John Adolfi
John Adolfi
  • 342 posts
  • Fulton, N.Y.
Posted 06 September 2007 - 06:16 AM
Does Final Cut pro 4-6 offer image stabilization in post and how much loss of information results from using this software?
#2 Jean Beaudoin
Jean Beaudoin
  • 56 posts
  • Digital Image Technician
  • MontrĂ©al
Posted 06 September 2007 - 07:13 AM
I have a better knowldge of AVID software with the Region Stabelize or the Stabelizer Effect.
The stabelized shot will loose as much information (E.G. will be cropped) as it is unstable.
If it is just a little shaky caused by the registration pin or a bad cassette you will loose about 5%.
The effect however is a little weird....because you are used to some life in the image and
that is removed by those effects. You cannot use these on a panning or zooming shot.
I guess FCP uses the same type of plug-in as AVID.
Just make some off-line tests. Good luck !
#3 Douglas Hunter
Douglas Hunter
  • 356 posts
Posted 06 September 2007 - 12:42 PM
I've tried to use the the stabilization in FCP 5 but I didn't much like the results. After Effects has wonderful stabilization abilities, it's got very good motion tracking and its very easy to tweek. go AE all the way.
#4 Sam Wells
Sam Wells
  • 1751 posts
Posted 06 September 2007 - 01:19 PM
The Smoothcam filter in FCP 6 (which is taken the Optical Flow technology in Shake) is surprisingly good.
Way better than what FCP had previously, no comparison.
-Sam
