Zeiss Standard T2.1 lens vs. Speed Panchro Series II or III
12 replies to this topic
#1 Tim Carroll
Tim Carroll
  • 2168 posts
  • Chicago, Illinois
Posted 08 September 2007 - 03:12 PM
Looking at the different options for 35mm lenses for a PL mount 35mm Arriflex and was wondering if anyone had experience with the Zeiss Standard T2.1 primes or the Cooke Speed Panchro Series II or Series III primes and had an opinion. It would be these Zeiss lenses, a 16mm, 24mm, 32mm, 50mm, and 85mm.
And it would be these Cooke lenses with a Les Bosher PL adapter, 18mm Ser. III, 25mm Ser. III, 32mm T2.3 Ser. II,40mm Ser. II, 50mm Ser. II, and 75mm Ser. II.
How do they perform as far as sharpness, color(are the Zeiss the usual cool and the Cookes the usual warm)? How far do you need to stop them down before they hit their sweet spot? And if you have used both, how do they compare to each other?
I realize this is a really broad question. I'm just beginning the exploration of 35mm. Any and all info would be greatly appreciated.
-Tim
#2 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 08 September 2007 - 04:35 PM
Hi Tim,
The lenses are quite different, the Zeiss Standards are far more modern & typically Zeiss, PL mount from the factory still used all the time.
The Cookes have a beautiful soft look, however as they are in their original state, focus pullers will have a hard time.
The Zeiss are more usable today IMO, be aware that the Zeiss 16mm & 24mm will porthhole when wide open on a digital sensor or P+S adapter, that's why they cost less than Super Speeds.
All of the lenses can be used wide open, however stopping down 1.5 stops you will see an improvement, if you want a very sharp image.
Stephen
-Tim
#3 Max Jacoby
Max Jacoby
  • 2955 posts
Posted 08 September 2007 - 04:42 PM
The Zeiss T2.1s actually do not have that razor sharp Zeiss look with a fast focus fall-off of the Ultra Primes and Master Primes. Instead they go a bit more in direction of Cooke look. But they are still plenty sharp, expecially if closed down. I recently saw an architectural shot comparison test and the Zeiss 14mm Distagon looked better than the equivalent Cooke S4.
#4 Tim Carroll
Tim Carroll
  • 2168 posts
  • Chicago, Illinois
Posted 08 September 2007 - 04:56 PM
Thanks Stephen and Max.
Stephen, I plan to use these lenses on an Arriflex 35mm camera, shooting 1.85, (in the academy frame, not full frame). Will I still run in to the porthole (is that the same as vignetting by the way?) problem when shooting with them wide open?
-Tim
#5 Max Jacoby
Max Jacoby
  • 2955 posts
Posted 08 September 2007 - 05:15 PM
Hi Tim
Shooting on film with these lenses is fine, film does not mind if the light hits it at an angle, sensors on the other hand do.
#6 Tim Carroll
Tim Carroll
  • 2168 posts
  • Chicago, Illinois
Posted 08 September 2007 - 05:21 PM
Hi Tim
Thanks Max.
-Tim
#7 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 08 September 2007 - 05:25 PM
-Tim
Hi Tim,
No problem whatsoever shooting on 35mm film. Portholing looks like vignetting, but the cause is different, when you stop down it goes away, with vignetting it will get worse!
Film does not care the angle that light hits it, a digital sensor does! I guess the Cookes may well have the same issue, but I have never tested them on a digital sensor.
Stephen
#8 Dan Goulder
Dan Goulder
  • 1259 posts
Posted 22 September 2007 - 12:53 PM
From which series was the Zeiss Distagon used in the test?
Thanks.
#9 Max Jacoby
Max Jacoby
  • 2955 posts
Posted 22 September 2007 - 01:02 PM
Thanks.
Standards I was told.
#10 Tim Carroll
Tim Carroll
  • 2168 posts
  • Chicago, Illinois
Posted 14 August 2008 - 07:53 PM
Okay, it is now about a year later, I have slowly put together a nice set of Speed Panchro lenses, one at a time. The set consists of the 18mm Ser III, the 25mm Ser III, the 32mm Ser II, the 40mm Ser II, the 50mm Ser II, and the 75mm Ser II. I had Guy at ZGC overhaul them all and have shot some test footage with all of them. They look good.
I had the chance to put them up on a lens projector today, and look at them next to a set of Zeiss Standard Speed Primes (the T2.1 versions) and a set of Zeiss Master Primes, and a set of Cooke S4 lenses. They stacked up really nicely with the Zeiss Standard Speed Primes, and have very similar characteristics. I was really surprised how sharp the Speed Panchros were, even wide open.
Naturally the Cooke S4 lenses blew away the Speed Panchros, and the Master Primes were unbelievable. Would love to have a set of those babies.
It was really great having the chance to look at the lenses with a lens projector. Would love to have a projector for my shop.
Best,
-Tim
#11 Adam Frisch FSF
Adam Frisch FSF
  • 2027 posts
  • Los Angeles, USA
Posted 15 August 2008 - 02:10 AM
The Standards are one of my favorite lens series.
They're light.
They have a great range.
They're sharp enough to feel modern, but soft enough to feel organic.
They perform well wide open.
#12 panagiotis agapitou
panagiotis agapitou
  • 35 posts
  • Greece
Posted 22 May 2018 - 03:49 PM
Please take a look at this thread .... : http://www.cinematography.com/index.php?showtopic=76505
May that be a very very early version of the standard primes 2.1  and tha'ts becouse the 24mm distagon was vignetting ???
Edited by panagiotis agapitou, 22 May 2018 - 03:54 PM.
#13 Dom Jaeger
Dom Jaeger
  • 1734 posts
  • Melbourne, Australia
Posted 22 May 2018 - 07:40 PM
The issue Stephen is talking about here with the wide Standard Speeds is not vignetting, but uneven illumination caused by the angle that the light hits a sensor. Most older lenses are not telecentric, and the wider angle focal lengths will often have some portholing effect on digital cameras, but unless you're shooting an evenly lit white wall or the like it's often not noticeable. Stopping down makes a lens more telecentric, so the portholing is reduced.
I should add that many older lenses will vignette, in the sense that they get a little darker towards the edges, due to the optical design (a simple lens will naturally condense more light in the centre than at the edges so even illumination needs to be designed into the lens), but this is different to what Stephen is talking about in this thread, which is to do with telecentricity.
I don't know what Garret Brown was joking about in that other thread, I haven't noticed the 24mm Zeiss Standard Speed having particularly noticeable vignetting issues, but maybe Kubrick with his keen eye had noticed it was worst on the 24mm?
