LTR7 frame rates question
#1 andrewwatson
andrewwatson
  • 19 posts
Posted 10 September 2007 - 10:30 PM
Hey, quick film question. I'm shooting on an LTR7 and have a quick question. On the frame rate knob it has the different frame rates. Its has the lower frame rates then 24, 28, and then two blank spots. The owner's manual says it goes up to 32. Do all LTR's only go up to 32, any chance the blank spaces are for 36 fps, or 48?
I'm doing a camera test tomorrow, so i can hopefully figure it out better, but just wondering if anyone has some knowledge here.
Thanks!
Andrew David Watson
www.andrewdavidwatson.com
#2 Nathan Milford
Nathan Milford
  • 692 posts
  • New York, NY
Posted 10 September 2007 - 11:19 PM
It should be 32fps. Some cameras have extra spaces on their speed dials for 29.97 or something else 'custom'. And then there is a blank space on the dial for the set screw that holds the dial on.
Some LTR7's have been factory modified to go 54 fps (essentially upgraded to LTR54's).
Still others have been modified by 3rd parties to go even higher... which scares the willies out of me.
#3 andrewwatson
andrewwatson
  • 19 posts
Posted 11 September 2007 - 08:37 AM
thanks! yes there is two blank spots and then a spot for the screw... do you think the blank spot before the screw, should be 32 fps?
thanks!
andrew
#4 daniel mahlknecht
daniel mahlknecht
  • 190 posts
  • Italy - South Tyrol
Posted 20 September 2007 - 01:42 PM
thanks!
andrew
#5 daniel mahlknecht
daniel mahlknecht
  • 190 posts
Posted 20 September 2007 - 01:49 PM
the white dot on the speed dial enables the crystal speeds 25 f/sec and 24 f/sec that you select from an separate switch.
Maybe you know this but from your posts I was not sure, and this is really important to know.
Daniel
