Arri IIC v. Eclair Cameflex
19 replies to this topic
#1 Charlot Vega
Charlot Vega
  • 16 posts
  • new york
Posted 18 September 2007 - 12:24 AM
Which was is louder? (I read the Eclair was 60 db, but can't anything about Arri IIC.)
and
Which one is, overall, the more reliable camera?
thx-charlot
#2 John Sprung
John Sprung
  • 4635 posts
Posted 18 September 2007 - 02:54 PM
and
thx-charlot
About a wash for noise, Arri is more reliable, and Arri parts and service are far more widely available.
#3 Chris Keth
Posted 18 September 2007 - 02:56 PM
I'd go with the arri. I've seen some fine arri 2s still around but have never seen a cameflex. There is probably a reason.
#4 John Sprung
John Sprung
  • 4635 posts
Posted 18 September 2007 - 03:55 PM
The main reason is that Arri made about 17,000 of the II A-B-C's, far more than any other make and model. They're more robust and from the "B" onward have better registration than the CM-3.
#5 Chris Keth
Posted 18 September 2007 - 04:28 PM
Does anyone service the cameflex anymore? I've never even seen one and rarely heard them spoken about.
#6 Charlot Vega
Charlot Vega
  • 16 posts
  • new york
Posted 18 September 2007 - 11:13 PM
Thanks for replying. And that's a very good point about service/parts. I think that alone could be a deciding factor.
Do you know of any films that mainly used Angineaux lenses? (the camera i'm looking to buy comes with one.)
I know the lens makes a huge difference for the image, so I wonder if there are certain films that a have a certain look because they use a certain lens? (Can a seasoned cinematographer see a film and know that Zeiss lenses were used?)
#7 James Steven Beverly
  • 4199 posts
  • El Paso, Texas
Posted 19 September 2007 - 01:57 AM
Well another factor is, or maybe SHOULD be, that there are also a ton of Arri2 blimps about. They come up on ebay from time to time. If you're worried about noise, that would solve your problem in spades. I know the Eclair also had blimps made for them but I think I've only seen 1 the entire time I've been checking the ebay lists. B)
#8 kevin jackman
kevin jackman
  • 350 posts
Posted 19 September 2007 - 01:30 PM
my understanding is that the eclair has a steadier image due to the double registration claws. it can be quieted down by removing the 16mm claw. the camera is also more easily converted to 2 perf which is why ive been wanting one. it can take 35mm lenses whereas im sure the arri cant. i have also seen a few people that service the eclair. theres opto electrical house, the supervision guy in the uk, aranda although ive hear suspect things about them, and berniw at super16.com. please offer more info people. id like to hear. im in the same dilemma. are there twin pin arris? how about conversion?
#9 Hans Engstrom
Hans Engstrom
  • 195 posts
  • Sweden
Posted 19 September 2007 - 07:06 PM
#10 Charlot Vega
Charlot Vega
  • 16 posts
  • new york
Posted 20 September 2007 - 12:58 AM
Has anyone ever worked with a 'sound matte'? I'm wondering just how effective this device is.
#11 kevin jackman
kevin jackman
  • 350 posts
Posted 20 September 2007 - 01:46 AM
sorry i meant 35mm still lenses
#12 Leo Anthony Vale
Leo Anthony Vale
  • 2010 posts
  • Pittsburgh PA
Posted 20 September 2007 - 02:10 PM
The Cameflex has a better viewfinder image. None of those light baffles.
& it's more comfortable for hand holding.
#13 John Sprung
John Sprung
  • 4635 posts
Posted 20 September 2007 - 02:12 PM
That's incorrect. The CM-3 has no registration pins, and no dwell claw. It uses a ratchet claw pulldown, which is much less precise than the cardioid cam/dwell setup of the Arri. The 16 claw has no effect on 35, though it does look like it should come dangerously close to scratching the 35. But I've never heard of that happening.
#14 John Sprung
John Sprung
  • 4635 posts
Posted 20 September 2007 - 02:16 PM
Here most of the rental inventory Arri II's have had the baffles removed -- you can just rip them out with a needle nose pliers. I never had any light leak problems with that. The downside to the Arri finder is that it doesn't quite cover the full Super width.
#15 kevin jackman
kevin jackman
  • 350 posts
Posted 21 September 2007 - 09:43 AM
i have what i think is a 2a...no markings saying its a B. i understand the claw is different from the B and C. does anybody know if this is true and if it can be converted? also, can the variable shutter be put in? my plan is to go to two perf. im kicking myself for not getting the tobin...
#16 Christian Appelt
Christian Appelt
  • 470 posts
Posted 21 September 2007 - 11:59 AM
Those baffles are there to prevent stray light reflected by the ground glass from hitting the film. With some older lens designs and in really bright conditions I have seen strange leak light effects on a "de-baffled" Arri that were not caused by leaks in the door or mag - we had done a check on that before. I wouldn't take them out unless there is a very good reason for it! :)
Edited by Christian Appelt, 21 September 2007 - 12:02 PM.
#17 John Sprung
John Sprung
  • 4635 posts
Posted 21 September 2007 - 12:28 PM
First, look at the serial number. The only thing I know about them is that #2000 is the first of the model II, anything under that is a model I. Perhaps someone else can give us the number ranges for the A, B, and C.
Then take the door off and inch the camera. Look at the mechanism that drives the claw up and down. As I understand it, from the II-B onward, this will be a cardioid cam about the size of a thumbnail. In the model I and early II, it's just a chrome disk with a small eccentric screw. I've heard it said that they also tried some sort of link mechanism in between, but I've never seen one.
As for conversions, first see what you have. It may be smarter to sell what you got and buy what you want -- check the numbers both ways before you go for a conversion. I had a II-C Techniscope parts kit years ago -- the gate, shutter, ground glass, etc. -- Sold it all for $250 in the early '90's.
#18 Charlie Peich
Charlie Peich
  • 247 posts
  • Chicago
Posted 21 September 2007 - 03:42 PM
I have a 2A It is marked 'II A' on the round disk cover just above the tach, and the original paint covering the screws is untouched. S.N# 3939. It has the cardioid cam movement and a 180-degree shutter. Academy gate. It's hard to tell if the camera came that way, or if it was modified. The camera was 1st bought from Arri in Sweden, and then it made it's way to the states by a photog that purchased it while working in Sweden. It still has the baffles in front of the ground glass.
If have to agree with Christian about the baffles. It was tried with a 35-3 that I know of, and the similar "reflection" problems occurred. The baffles were put back as it was too difficult to predict when and under what exact conditions the reflections would occur.
#19 chuck colburn
chuck colburn
  • 389 posts
  • orygun
Posted 21 September 2007 - 06:07 PM
That's why it's best not to mount the spinning mirror at a 45 degree angle to the film plane.
#20 kevin jackman
kevin jackman
  • 350 posts
Posted 23 September 2007 - 01:16 AM
does anybody have a link to somebody that does a 2 perf conversion and claw upgrade?
