35mm ground glass…
#1 Jay Taylor
Jay Taylor
  • 122 posts
  • Nashville, TN
Posted 21 September 2007 - 11:45 AM
Hey guys, real quick question!
If the ground glass is "Accd centering with TV/185 markings" what does that mean exactly?
I'm assuming "Accd" means academy centered? As opposed to full frame? And then "TV/185" seems obvious enough, but I'm curious if there's a difference between tv and 1.33 ground glass?
Thanks for your help!
Jay
  • 20073 posts
Posted 21 September 2007 - 07:15 PM
Yes, it probably means "Academy".
4x3 TV and Academy are rather similar, but TV is 1.33 and Academy is 1.37, plus TV usually means "TV Safe / Title Safe" and gives you are 10% space on all sides of the transmitted 4x3 area to account for overscan, so it's a smaller 4x3 rectangle than Academy. 1.85 and Academy share the same width but "TV Safe" is less wide than both.
Also, "TV Safe / Title Safe" doesn't mean that what's outside the lines are not in TV, it means what's inside the lines will be visible on most TV's even after overscan.
#3 Jay Taylor
Jay Taylor
  • 122 posts
  • Nashville, TN
Posted 21 September 2007 - 09:19 PM
Perfect explanation! Thanks a bunch, Mr. Mullen!
Jay
