Lens Shading on HDX-900 w/ Digiprimes
#1 Scott Sanss
Scott Sanss
  • 2 posts
Posted 22 September 2007 - 09:20 AM
Hey I wanted to know if there is a diffrent procedure for establishing Lens Shading with Digiprimes?
Is it the same as all other ENG (B4) lenses>?
How often should shading be reset?
Thanks in advance
Edited by Scott Sanss, 22 September 2007 - 09:21 AM.
#2 Chris Keth
Posted 23 September 2007 - 01:56 AM
I'm not sure I get your question. Are you talking about flagging the lens to prevent flares and loss of contrast?
If that's what you're talking about, you do it whenever you need to do it, basically. It doesn't matter what lenses you're using.
#3 Chad Stockfleth
Chad Stockfleth
  • 622 posts
  • Louisville, KY
Posted 23 September 2007 - 10:20 AM
No, he's talking about the camera's internal lens shading function that let's you account for aberrations in the lens so that a set is consistent.
The process should be the same with digiprimes as with an eng lens, as far as I know.
#4 Mitch Gross
Mitch Gross
  • 2873 posts
Posted 24 September 2007 - 10:36 AM
Setting the white shading for any lens is the same process no matter the optics.
