7218 overexposed or 7217?
12 replies to this topic
#1 Diego Lazo
Diego Lazo
  • 8 posts
  • Santiago, Chile
Posted 22 September 2007 - 05:05 PM
I`m shooting a short in a few weeks and I don`t have any money for testing (I live in Chile, South America, and shooting 16 mm is a bit expensive). I`ve had a previous experience with Fuji Reala 500D and the results were really bad. Too much grain. This time I`m thinking about using Kodak 7218 because I have a lot of interiors and my lighting kit is mainly composed by tungsten fresnels (650 W, 1 KW and 2KW) and some practicals. Also, I have limited power because the house where I`m filming has only 25 amps. I don`t want to commit the same mistake with the Reala (i didn`t overexposed the negative), so I`m thinking in setting my lightmeter at 320 ASA (2/3 stop over) or 250 ASA (1 stop over). Now, is this a good decision or should I change my mind and go for Kodak 7217 instead? The short is about skin, sexual tension, desire and that kind of stuff so I really want the best stock for these concepts.
Saludos y Muchas Gracias ;)
Diego.
#2 Chris Keth
Posted 22 September 2007 - 07:20 PM
Diego.
I like 2/3 overexposure with 7218. You're still going to have a rough time with onle 25 amps of power total.
#3 Chris Walters
Chris Walters
  • 82 posts
Posted 22 September 2007 - 07:22 PM
Personally I like the 18 stock but always overexpose by at least 2/3 - stop over just to get tighter grain structure and bring it back down in post to get nicer blacks. Always safe to overexpose than underexpose too. All thats my opinion and it really matters how you want it to look. I think the skin tone would be better with less grain and with the amount of lights and power you say you have its better to overexpose 18.
Chris Walters
#4 Diego Lazo
Diego Lazo
  • 8 posts
  • Santiago, Chile
Posted 22 September 2007 - 09:30 PM
Yeah, I know I`m very limited with 25 amps. My producer is trying to get some Kinos and some other low-power lights.
Has anyone work with 7217 before?
#5 Kevin Zanit
Kevin Zanit
  • 1223 posts
  • LA
Posted 22 September 2007 - 09:35 PM
I have shot plenty of 5217 and 5218, not a lot in 16mm though. That said, use the '18 - Shooting 5217 at 160 (over exposing by a 1/3 of a stop) or at 200 is not very viable with the amount of light you have unless its all close ups. There is not a huge difference in grain between the two to be honest, not as much as you would think.
#6 Anthony Schilling
Anthony Schilling
  • 1063 posts
  • Portland, OR
Posted 23 September 2007 - 11:30 AM
I agree, 7218 in 16mm is not that grainy. If you can overexpose it 2/3rds, would be a world of difference than underexposed 200T.
#7 Diego Lazo
Diego Lazo
  • 8 posts
  • Santiago, Chile
Posted 23 September 2007 - 11:56 AM
Will go for the 18 then.
Thank you guys for the quick response.
#8 Adam Thompson
Adam Thompson
  • 161 posts
Posted 23 September 2007 - 01:22 PM
For safety maybe going over by a stop is a good idea for telecine, but if everything is known and controlled, rating it at 500 works perfect for me and if your sets are small, that kit sounds like it could work with fast lenses. I've had to do with less once or twice.
To quote something I just read in AC:
"I used to rate the Kodak's 500T 5218 at 320 or 400... but with the Vision 2 stocks I don't need to get quite such a thick negative to get the same result so I actually rated them at what was written on the can." Oliver Wood -shooting The Bourne Ultimatum
#9 Rick Shepardson
Rick Shepardson
  • 56 posts
Posted 23 September 2007 - 02:13 PM
Diego.
It may be that the transfer house you are going to only uses something like a one k transfer. I say this only because I've had a similar experience. I shot 16mm 500t and transfered it using the one k process we have where I go to school. It ended up looking very grainy and flat like video. However, I have heard of students getting a two k transfer with the same stock and getting much more satisfying results.
I hope this helps
-Rick Shepardson
Edited by Rick Shepardson, 23 September 2007 - 02:14 PM.
#10 Diego Lazo
Diego Lazo
  • 8 posts
  • Santiago, Chile
Posted 24 September 2007 - 11:45 AM
Well, I know that 16 mm has more grain and less definition than 35 mm. So, it is better to overexpose the negative when you work with a faster negative in 16 mm and you don`t want too much grain in your image.
I hope this helps
-Rick Shepardson
This makes sense. The Reala stuff was transfered in an old machine. This time I`m going for a URSA Diamond Y Front with a Da Vinci DUI Color Corrector. Now, I think that the URSA is not 2K but I`ve seen really good results with this machine.
#11 Michael Nash
Michael Nash
  • 3330 posts
  • Pasadena, CA
Posted 24 September 2007 - 05:50 PM
It's neither 1K nor 2K -- it's a video telecine, not a data scan.
http://www.cintel.co...ducts_ursa.html
http://www.cintel.co...s_creality.html
#12 Chris Keth
Posted 24 September 2007 - 06:59 PM
That may be for 35mm but for 16 I would still overexpose to tighten up the grain. It's not such a big deal in 35.
#13 Adam Thompson
Adam Thompson
  • 161 posts
Posted 27 September 2007 - 03:15 AM
If you can do it, it probably is a good policy overall, but I wouldn't not shoot if I couldnt get over due to lack of lighting, etc.. I did a short a couple years ago on Reala and had to wait out part of the morning until a room got to a 2.8 via sunlight bouncing in through two windows. There were no lights at all. Since I had an old Ang. zoom I was worried since it was so slow, but it all came out fine. I guess if you really need the clean, no grain look, then that's not the best route, but it fit that project well. Though Reala seems to be a little overly grainy no matter what you do.
