Checkinh a film stock?
10 replies to this topic
#1 Filip Syczynski
Filip Syczynski
  • 1 posts
Posted 15 October 2007 - 07:03 AM
Hi!
A few days ago I bought some older (2004) 35mm film stock, each for just 10£ so I thought that I wouldn't lose much by just risking it (3 x 400ft Kodak Eastman 250D 7297 1R 3 x 400ft Kodak Vision2 100T 7212 1R ). I wanted to ask, if there is a chance of maybe testing the stock (just some 20ft?) before shooting anything on it? (not to gather all the crew, actors etc. and then the footage would come out black after processing... that would be a disaster).
#2 Tim Carroll
Tim Carroll
  • 2168 posts
  • Chicago, Illinois
Posted 15 October 2007 - 08:58 AM
In the past I've done a "clip test" (I think it's called). Shoot about ten to twenty feet, send it to a lab and have it processed, and then look at it with a light table and a loop.
-Tim
#3 John Brawley
John Brawley
  • 834 posts
  • Atlanta Georgia
Posted 15 October 2007 - 10:11 AM
Hi!
Hi Filip...
you can ask a lab to do a dip test for you. They'll take a few feet off your roll and process it. Then they measure the base density and then give you a figure. I vaguely recall more than +10 in R G or B wasn't good. Of course...it never stopped me from shooting with it....:-)
jb
#4 Filip Syczynski
Filip Syczynski
  • 1 posts
Posted 15 October 2007 - 02:16 PM
Thank You for your help! I'll do the tests ASAP
#5 Jonathan Bowerbank
Jonathan Bowerbank
  • 2815 posts
Posted 15 October 2007 - 10:35 PM
You don't even have to shoot anything, just cut a few feet off and send it to the lab for the clip test. They'll test its density and let you know what sort of condition its in.
#6 A. Whitehouse
A. Whitehouse
  • 267 posts
  • Melbourne
Posted 16 October 2007 - 03:23 AM
Just be aware that the dip tests are very precise and Ive shot whole shorts with few problems on stock that was declared unusable and no good at the lab. If your going a TK or Digital route it isn't as much of a big deal. On my own project I made sure to shoot the first 30 feet of each roll for make-up, filter, lens tests etc. It was a pain in the ass but my stock had been in a fridge for 5 years +. It was interesting shooting on 5293 in a world of V2s. While I knew that the stock had been well taken care of before it had hit my fridge (i scored it from a really large production) age does take its toll and it showed up in grain on some rolls. Anyway, don't give up hope if the tests come back negative but go into this with your eyes open.
Sasha
#7 Sam Wells
Sam Wells
  • 1751 posts
Posted 17 October 2007 - 11:37 AM
Hi!
You are aware, I hope, that these numbers refer to single perf (1R) 16mm stock, not 35mm ?
-Sam
#8 Andrew Brinkhaus
Andrew Brinkhaus
  • 176 posts
Posted 24 October 2007 - 10:55 PM
Another quick test to see the results of the stock would be to just buy a cheap bulk loader, and cut a foot or so and load it up in a 35mm photo canister, and shoot a roll on a still camera. Get it developed wherever, and check your prints when you get them back for any major damage/defects to the film.
#9 Frank Cook
Frank Cook
  • 42 posts
  • Alaska
Posted 25 October 2007 - 02:40 AM
DON'T DO THIS!!!!
Most motion picture film has a coating that will RUIN a "mall mini-lab." Do NOT develop this film at a local shop. The coating plugs the plumbing system. It coats big bucks to fix! The lab owner will hate you, and might want you to pay the thousand of dollars it costs to make the repairs (ie. take you to court). :blink:
#10 Hal Smith
Hal Smith
  • 2280 posts
  • OKC area
Posted 25 October 2007 - 12:48 PM
I believe John Pytlak once said that all it took to get the Remjet backing off was a hot water bath. If that's correct, then it should be possible to pull the Remjet off exposed film in a simple home darkroom process, dry the film, reload it into the still cannister, and then take it to the minilab machine. Anyone ever try this?
(Turns out this isn't correct, see following information)
I found the thread discussing DIY processing:
John PytlakFeb 13 2006, 12:10 AM
(Paul Bruening @ Feb 4 2006, 02:57 PM) <{POST_SNAPBACK}>
Karl, thanks for great info,
What's the best way to remove the remjet backing? Will it come off with just water jets or does it require some form of physical contact? Would a series of sponges do the job? What about a soft centrifugal roller from a squeege works?
The Kodak H-24 ECN-2 processing specifications include a high salt alkaline prebath to soften the rem-jet (but leave it on the film in the tank), then a directed water wash-off (to remove most of the rem-jet and not have the particles get back on the film), and finally buffing with more water wash off (to remove the residual binder).
Doing it by hand (in total darkness) will likely remove most of it, but it is difficult to not have some particles get attached to the film as your sponges/buffers load, and some gets pushed through the perfs.
Full thread here: <a href="http://www.cinematography.com/forum2004/lo...php?t11703.html" rel="nofollow" target="_blank">http://www.cinematography.com/forum2004/lo...php?t11703.html</a>
#11 Nick Mulder
Nick Mulder
  • 1023 posts
  • Auckland, New Zealand
Posted 25 October 2007 - 01:40 PM
its redundant as Sam has already mentioned - its 16mm stock ...
