high speed camera..do they all use taylor reels?
#1 kevin jackman
kevin jackman
  • 350 posts
Posted 15 October 2007 - 02:18 PM
or are there some that dont?
#2 Leo Anthony Vale
Leo Anthony Vale
  • 2010 posts
  • Pittsburgh PA
Posted 15 October 2007 - 03:46 PM
Projection reels?
#3 kevin jackman
kevin jackman
  • 350 posts
Posted 15 October 2007 - 03:52 PM
Projection reels?
my understanding is that high speed cameras need the film loaded onto something that looks like a large daylight spool. they are called taylor reels
#4 Robert Houllahan
Robert Houllahan
  • 1626 posts
  • Providence R.I.
Posted 15 October 2007 - 05:35 PM
All Redlake or Visual Instrument Hycam cameras need 400' daylight spools and the film for these cameras is usually 500t 7218 on estar base delivered from Kodak on the daylight reels. A hycam will pull a 400' reel in 1.5 sec so a core is potentially troublesome.
I do not think you need daylight reels with a Photosonics.
-Rob-
#5 Charlie Peich
Charlie Peich
  • 247 posts
  • Chicago
Posted 15 October 2007 - 09:15 PM
The Action Master 500 needs daylight spools. The daylight spools in 400ft size that are often used are "split reels" which use regular cores. You are able to order film for High-Speed cameras in 400ft rolls on a daylight spool from Kodak. This is double perf with a long pitch of 0.3000" ... 2R-3000. The Action Master takes either 0.2994" or 0.3000" pitch. Most other High-Speed cameras take long pitch.
Kodak at one time had High-Speed Camera film in 50 ft rolls (2R-3000) mounted on a "Tayloreel Microfilm Spool". Not many takes on that roll! I don't know if Tayloreel still makes the 50ft spool.
#6 Janne Pulkkila
Janne Pulkkila
  • 17 posts
  • Finland
Posted 25 October 2007 - 06:30 PM
Usually, I have loaded a LOCAM with an acetate based, double perfed, 0.2994 pitched film on a regular 100 ft daylight spool. Works fine at 500 fps.
The camera is so complicated to load that you couldn't possibly do that in total darkness.
#7 Mark Dunn
Mark Dunn
  • 2660 posts
Posted 27 October 2007 - 06:16 AM
Those Taylor reels don't look like the same as daylight spools. They don't really have to deal with fast-moving film. The issue isn't so much daylight loading as keeping the film running true at high speed. (We used to call the LOCAM medium-speed- high speed for us was up to 10,000fps so the film was moving at 170 mph. 400' of VNF in two seconds flat).
The R-90 (100'), R-190 (200') and the S-153 (400') spools are balanced to run true.
We threw them away by the hundred.
