15EPSS motor of Konvas cameras
#1 Olex Kalynychenko
Olex Kalynychenko
  • 868 posts
  • Dnepropetrovsk, Ukraine
Posted 17 October 2007 - 06:27 AM
I wish give technical information about popular motor of Konvas-1M, Konvas-2M cameras - 15EPSS.
[attachment=2797:15_motor_1_mini.jpg]
The many users of Konvas cameras with 15EPSS motor send me many questions and i wish give base information.
The user manual wrote:
The electrical motor of 15 EPSS use with Konvas-1M (1KSR-1M ) , Konvas-2M ( 1 KSR-2M ) cameras.
The original battery - 5 cells of SCS-15 ( russian silver-zinc cells) 15ah and nominal output 7.2-8.5V.
15EPSS motor have speeds : 8 fps ( 480 rpm ), 16 fps ( 960 rpm), 24 fps ( 1440 rp, ) 32 fps ( 1920 rpm).
The deviation of speed on 24 fps ( 1440 rpm ) +/- 2.5%
The deviation of speed on 8, 16, 32 fps +/- 4.0%
The nominal turning moment 600 (gram/m) at 8, 16, 24 fps and 700 gram/m at 32 fps.
The motor can give you maximum turning moment 1000 gram/m at 24 fps and 1200 gram/m at 32 fps on forced mode with time of work 1 minute and time of waiting 5 minutes.
The value of noise 48 Db
The worker temperature air - 30C ..+40C
Size of power unit 200 x 95 x 220 mm, weight power unit and motor module 6.2 kg.
Description.
15EPSS motor included power unit with battery and motor module.
The motor modules included two power DC motors 27V 9000 rpm on one axis, feed back and reducer 3:1
the power DC motors connect in series.
The power unit included electronic voltage trasnformer from 8.5 v battery on 45 v output with power 65..75W and module of speed conrol.
The speed control modyle have type of " analog system of speed stabilization.
The many users of 15EPSS motor ask, what kinds of battery can be use.
The original battery have 8.5 v output and 15 AH power. But, now, polular SLA batteries with 6 v and 12 v poutput.
I hear about a some 8.5 v batteries, but, this is low power batteries with 2.5ah and similar.
The users ask about use of 12 v batteries.
I wish underline, 12 v battery can burn down of electronics of motor.
This can be with connect of 12 v battery or after a some time of work.
And i repair of many power units after user connected of 12 v battery.
The matter is that, the base generator of power unit with 12 v battery have output 100 v.
And power transformer have output 78 v.
This is too high voltage for many transistors of power unit.
The transistors of power unit have maximum voltage 60v( output stage ) and 40 v ( other).
That's why, this is transitors can burn down.
The power unit have high power 60v, 10 A, germanium transistors with low loss at P-N-P structure.
About 6 v battery.
The power unit can work with 6 v battery, but, we have other situation.
The 6 v battery not enough for generate by voltage transformer output voltage for speed 24 and 32 fps.
24 fps can for with charged 6 v battery, but, the power spare can be low and speed can be non sync.
The output of voltage transformer have voltage 24 v only.
With 8.5 v battery, the voltage transformer have output 40..45v.
You can see, the 27 v DC motors, connected in series will have low speed at 24 v.
You will have good sync on 8, 16 fps, but, can lost sync at 24 fps and don't have sync at 32 fps.
The power unit of 15EPSS motor can be upgrade for work with 6 v battery.
The upgraded voltage transformer have output 39..42 v and this voltage enough for good sync on 24 and 32 fps with 6 v battery.
The modified power unit can work with 6 v 4ah, 6v 10ah and more high power battery.
The Speeds of power unit can be change and you can set of other speeds.
The power unit have block of variable resistors ( at battery module ) and you can adjust of every speed.
The power unit can have two versions with 5 or 6 variable resistors and can have outside switch for work with low or normal temperature of air.
#2 Bruce Taylor
Bruce Taylor
  • 482 posts
Posted 19 October 2007 - 02:54 PM
Thank you Olex for the very useful information. It is good to know that you can make the units more reliable and useful- there have been so many questions about batteries and faulty control boxes.
-Bruce
#3 Roy Cross
Roy Cross
  • 29 posts
  • Montreal
Posted 04 November 2007 - 09:22 PM
Yes, I second those comments by Bruce. Many thanks Olex.
Roy in Montreal
Edited by Roy Cross, 04 November 2007 - 09:22 PM.
