Broken Scoopic...
#1 henry jameson
henry jameson
  • 24 posts
Posted 21 October 2007 - 03:40 AM
hi, yesterday i finally managed to recell the battery pack of my Canon Scoopic.
Everything seems to work, auto expose works (is it normal to be quite noisy when changing aperture?). Set fps to 16 and pressing the button it seems to be running, but when i tried to load the film i found out that nothing turns in the film compartment... it just makes noise but no movement at all.
Anybody can tell me where can i send it in Europe to be checked and what could be an estimated cost ? i'm not sure if it's worth it at this point..... :angry:
#2 stephen defilippi
stephen defilippi
  • 45 posts
Posted 21 October 2007 - 04:24 PM
Hi Henry. Try turning the black knob inside of the film compartment as you hold down the run button. Also sometimes the motors move a bit (shift because the screws that hold the bracket become loose) and this causes jamming. Im not an expert, but ive done minor repairs in the gear box and ive adjusted the motor position easily and this helped with mine which now runs perfectly.
Also make sure the single exposure button is disengaged (if it has one).
stephen
#3 henry jameson
henry jameson
  • 24 posts
Posted 22 October 2007 - 07:30 AM
[quote name='stephen defilippi' date='Oct 21 2007, 11:24 PM' post='199498']
what black knob do you mean ? here's a pic from the 16M manual
it doesn't have single exposure... it's just as if the motor isn't connected to anything.... seems like a broken sprocket/gear.....
#4 stephen defilippi
stephen defilippi
  • 45 posts
Posted 22 October 2007 - 12:24 PM
Look at the photo on the right. The black knob is just to the left of the hand.
the motor on this camera is not that big. its not likely that it has broken a gear or sprocket.
cheers
#5 henry jameson
henry jameson
  • 24 posts
Posted 24 October 2007 - 01:48 AM
ok i managed to get things moving. Somehow the film guide was in an intermediate position. After playing around a bit i got things moving. I managed to load the film, but had to remove the pressure plate cos it always got stuck. After the film has been thread and wound on take up reel i put back on pressure plate and everything seems fine. Took some shots yesterday and film counter is advancing, so it should be working...
