Chrosziel Matte box on JVC DV5000
No replies to this topic
#1 Dave Felder
Dave Felder
  • 5 posts
Posted 25 October 2007 - 03:28 PM
I picked up a used Chrosziel matte box that I'd like to adapt to my JVC DY5000.
There is no model number on the matte box. It has two filter holders stamped 402-04, one of which rotates. The matte box has a mounting adapter stamped Dia 102, and it has an inside diameter of 102mm. There are 4 mounting nubs that the adapter fits over, then you turn it about 5 degrees to lock it into place.
The JVC has a Fujinon lens S17X66BRM-SD that takes an 82mm screw in filter, and it has an 85 mm outer diameter.
Should I be looking for a 102mm - 85mm step down ring? Or is the 104mm step down ring, which seems to be on every vendor's web site, what I need?
