Recognizing focal lengths
#1 cal bickford
cal bickford
  • 12 posts
Posted 28 October 2007 - 08:59 PM
Hi I'm trying to practice recognizing focal lengths used in movies so that I can better envision a shot and since I don't have access to a 35mm camera and lenses, watching movies is the only way to do it. I was wondering this: do you guys have any screenshots that you know were shot with a certain focal length or know of any movies that used only one or two lenses such that i might be able to pick them out while watching etc? or any other resources or ideas? thanks.
#2 Chris Keth
Posted 29 October 2007 - 01:03 AM
I'm not really sure that's possible, to be honest. A 32mm looks very close to a 35mm and a 35mm looks quite close to a 40mm. Worse yet, it gets even tougher on the long end of the scale. A 500mm looks surprisingly similar to a 1000mm unless you know the actual subject distance.
Why do you need to know the exact focal length of a particular shot, anyway? Wouldn't it be more useful to you to know what lenses look like in terms of wide, normal, long, really wide, et cetera? After all, learning to recognize the focal length in terms of the format would give you the experience of recognizing the actual qualities of that type of lens, not just a number.
Edited by Chris Keth, 29 October 2007 - 01:05 AM.
#3 Jonathan Bowerbank
Jonathan Bowerbank
  • 2815 posts
Posted 29 October 2007 - 01:52 AM
Go the cheap route. Get a 35mm SLR camera and get familiar with various focal lengths.
#4 David Mullen ASC
Posted 29 October 2007 - 02:13 AM
Well, a DSLR would be even better since the sensor size is the same as a 35mm movie frame, so the focal lengths are similar, as opposed to an 8-perf 35mm still camera frame.
You can look at a few historical examples, though you have to factor in things like masking -- for example, a lot of the wide-angle shots in "Citizen Kane" were done with a 25mm lens and Ozu was famous for shooting whole movies on a 50mm lens, but those were 1.37 Academy movies, so the same lens image would be cropped vertically in 1.85 projection in modern movies and thus feel slightly longer.
"Bottle Rocket" was mostly shot on a 27mm lens and "Rushmore" was mostly shot on a 40mm anamorphic lens. So was "Chinatown".
Many wide-angle shots in "Touch of Evil" used an 18mm lens.
#5 Max Jacoby
Max Jacoby
  • 2955 posts
Posted 29 October 2007 - 04:30 AM
Robert Bresson was another director who shot everything with the 50mm. In a discussion about Theo Angelopoulos 'Travelling Players' Remi said that the whole film was shot on a 35mm lens.
There are a few directors who only use a limited amount of lenses. People like the Cohen Brothers, Terry Gilliam, Jean-Pierre Jeunet and Tim Burton seem to stay on the wider end most, if not all, of the time.
I once worked on a feature of a friend as script supervisor. I made it a game to guess the focal lenghts by just looking at the monitor and then checking with the 2nd AC. I was about right 50% of the time, but keep in mind that I knew the size of the location, what focal lenghts we carried, etc...
#6 cal bickford
cal bickford
  • 12 posts
Posted 29 October 2007 - 02:32 PM
Thanks so far guys, this is exactly the type of stuff I'm looking for. You're right chris, being able to recognize the difference between a 32mm and 35mm is probably both impossible and useless. But I do think that being able to recognize the difference betwenn say a 28mm and a 40mm will help my visualization process immensly. I also think it will help me understand different directors' processes - why they go from one lens to another and when, etc. I know there's no correct method to lens choice but the more I understand about other peoples' work the more comfortable and prepared i think i'll be when i finally get my shot. I can definitely tell a wide shot from a telephoto shot from an ultra-wide shot but thats about it at this point. I'm really interested in hearing examples of specific focal lengths such that I can get a feel for the difference between a 24mm and a 35mm etc. A cheap 35mm still camera is a good idea to study the "scope" of a particular focal length, but I'm also interested in the lens's treatment of motion (both objects/characters through the frame and motion of the camera) and the director's process (why/when they use different lenses). Thanks for all the info so far, any more guys?
Edited by cal bickford, 29 October 2007 - 02:34 PM.
#7 Michael Nash
Michael Nash
  • 3330 posts
  • Pasadena, CA
Posted 29 October 2007 - 05:07 PM
Start simple. First maybe just try to break it down into focal ranges. I still think of shots that way -- wide, medium-wide, normal, medium-tight, and tight (<25, 35, 50, 85, 100+ in 35mm terms). That's much more useful from a storytelling standpoint anyway, so that the audience can distinguish a change in shot size easily. On set you'll get more particular with slight adjustments in focal length for more practical reasons.
One common approach to filmmaking is to tell the bulk of a scene with the camera at a consistent distance from the action, so that the lens changes create the changes in shot size (master on a 25mm , two-shot on a 50mm, and singles on an 85). But that's just one very simple, rudimentary approach.
Typically closeups ("singles") are done at a focal length that's "medium tight" or around 85mm in the 35mm format. This is usally the most flattering on the actor's face by avoiding any wide-angle distortion, and you get a shallower depth of field for that shot (where you want the audience's attention focused on the character at that moment anyway). But again, this is only a basic approach. Some filmmakers get a distinct feel and presence of the action by bending this "rule" and getting the camera much closer, with shorter focal lengths (or by doing the opposite, with really long lenses).
Oh, and also pay attention to the point of view that's suggested by the combination of focal length and distance to subject. Filmmakers often use the camera to shift the point of view for narrative purposes, like suddenly coming close for a single to put us in the character's space, or creating a sudden omniscient p.o.v. by moving the camera farther away.
There are no consistent rules between filmmakers, yet a good film has its own distinct visual language or grammar. Maybe take one film at a time, and look for the pattern of focal length to shot size. You'll find that the rules or language of one film often don't apply to another.
You might want to check out these books:
http://www.amazon.co...r/dp/193290705X
http://www.amazon.co...5406477-8144108
