How to apply ND to windows?
11 replies to this topic
#1 Dirk DeJonghe
Dirk DeJonghe
  • 612 posts
  • Kortrijk,Belgium
Posted 04 November 2007 - 04:56 AM
Can someone explain to me how to apply ND sheets (Rosco) to a window in a door? I know you have to use a liquid and then squeegee it out but what kind of liquid?
Any tips?
Thanks.
#2 Remi Adefarasin
Remi Adefarasin
  • 32 posts
Posted 04 November 2007 - 05:51 AM
Try using baby oil. Pre-cut your gel first or it will get messy. Then use a tissue to smear the oil around the windows edge. 3/4" smear. You don't need to go right to the edge. Then squeegee the air bubbles out. It works real neat & cleans up a treat with some tissues.
Remi
#3 Jonathan Bowerbank
Jonathan Bowerbank
  • 2815 posts
Posted 04 November 2007 - 01:47 PM
I've used soapy water before, and the ND held for 3 days. Just be careful in how much water you use, you won't need much.
On one shoot I was on, they used to much water and it gave the window a weird wavy appearance, but then by the next morning it looked perfectly fine. So it's a good idea to take care of it the day before a shoot if you've never done it before.
#4 Walter Graff
Walter Graff
  • 1334 posts
  • New York City
Posted 04 November 2007 - 01:56 PM
I'd not use baby oil. It is not a good idea. The way we do it is with either plain water or water with a touch of soap added. Use a spray bottle and squeegee from the center out. That is all you need to get good cohesion to a window with gels. Water will hold it for the shoot day and soapy water (dishwashing liquid) for even longer.
#5 Alex Ryle
Alex Ryle
  • 1 posts
Posted 04 November 2007 - 02:04 PM
Hi There
I'd definitely second the water idea - soapy or otherwise. I've often used a spritzer with clean water for this. A good squeegee is a must.
One thing to watch out for is dusty gel - all surfaces have to be clean before you start (I've been caught out by gels having picked up dust due to static - you end up with a strange bumpy/bubbly appearance - fine for distant backgrounds but not so good on car windows 6" from the talent!)
Cheers
Alex
#6 Hal Smith
Hal Smith
  • 2280 posts
  • OKC area
Rosco has a detergent solution they recommend but I can't find my notes. Contact Rosco technical support, someone there will know what is their witch's brew.
#7 robert duke
robert duke
  • 438 posts
  • Grip
  • southeast USA
Posted 05 November 2007 - 12:56 AM
the Key I am working with right now used water and sprite mixed, I dont know the mixture, in a spray bottle. Then Squeeged. The rigging key hung some large windows using paper tape and snot tape. Paper then snot on top. It was fast and dirty.
#8 Remi Adefarasin
Remi Adefarasin
  • 32 posts
Posted 07 November 2007 - 04:47 AM
Don't knock baby oil till you've tried it. I was a doubter too. Only round the edges mind. The centre stays totally dry.
#9 Walter Graff
Walter Graff
  • 1334 posts
  • New York City
Posted 07 November 2007 - 06:50 AM
I don't doubt it, but here's the problem I have with it. To walk into someone home, or establishment and put oil on their windows, and perhaps expensive windows with nice dressings, with ANY potential at leaving their home not exactly like one left it is not acceptable to me. I do not know anyone in the states that uses or would even consider such a thing. To me it would be the equivalent of putting a PVC dolly down on someone's carpet and spraying the tracks to lubricate them with WD40 or 3 in 1 oil. Sure it may work, but what might the consequences be, and what kind of clean up am I going to have. It's just not something I would suggest when a simple spray bottle, water and a teaspoon of soap does the trick, and doesn't leave odor or residue and cleans up real easy with no residue on your windows, crew, or any other part of someones home. Perhaps in the UK it is something that works, but for a novice filmmaker I would not suggest it.
Edited by WALTER GRAFF, 07 November 2007 - 06:54 AM.
#10 Alessandro Machi
Alessandro Machi
  • 3323 posts
  • California
Posted 07 November 2007 - 07:57 PM
I heard that the baby oil option is used primarily for porn movies. It was discovered by accident after filming an oil on oil wrestling scene in which the two performers brushed up against a glass... oh well, apparently one had to be there. Ironically the lead star's name was Endy.
As for using soap and water, just make sure the owners of the property don't see you lathering up their windows because they just may expect you or your crew to clean up each and every window after the shoot is done.
#11 Jon Rosenbloom
Jon Rosenbloom
  • 713 posts
Posted 09 November 2007 - 01:15 PM
It helps to have a clean window, but I haven't used a squeegee in years; just 1/2" clear double stick tape, which you apply all around the outer edge of the glass. It doesn't really matter what you use to adhere the gel to the window - as long as it doesn't show, sticks and can be removed at wrap. The main thing is to sweep any excess gel from the center out the edge, and then have a good new blade to trim away the excess.
Here's a shot w/ full cto on the inside of the windows, done w/ double stick clear tape - no oil, or soapy water or squeegee:
#12 John Sprung
John Sprung
  • 4635 posts
Posted 09 November 2007 - 03:30 PM
Another thought -- Home Depot sells a couple kinds of ND/reflective material for semi-permanent installation on glass. They come with some sort of spray bottle stuff that's supposed to hold for as long as you want, and come off clean. Has anybody tried that?
