music video redcam testshooting
16 replies to this topic
#1 Rainer Fritz
Rainer Fritz
Posted 08 November 2007 - 10:08 PM
Hello Everybody!
We shot last tuesday and wednesday a musicvideo with a young austrian band. That this happened was not luck in the last second, it was more than this...
The man who helped us in the very last minuite was Edwin Verstegen from http://www.hetraam.nl/ . He took a airplane on monday afternoon with his Red #49 and came to vienna and supported us in so much cases... he is a great cinematographer, and for shure a so relaxt and lovely person... thanks a lot on this way.
The camery worked very well on build 8 the hole 16 hour and the hole 7 hour shooting days. At one second I thought all will be over, as in the cf slot some of these golden tiny connector pins were bend. Probably they tried to pull it to hard in. But Edwin solved the problem with a huge amount of concentration and tactfulness.
Everybody was working very hard on this video... thanks to all again here by this way.
So I have now two clips online: (it is only a fast cut from only 10 files not the endversion... just for looking a little bit in the material)
So, I go now for bed to sleep some hours...
thx for comments in advance...
small:
http://redcamservice...eoH264small.mov
bigger
http://redcamservice...deoH264720p.mov
regards rainer
#2 Evan Winter
Evan Winter
  • 202 posts
Posted 09 November 2007 - 02:59 AM
Great looking stuff. I like the frontal perf. close-up and thought the tunnel shot (where the camera pulls away from the lead singer) was quite cool. Thanks for sharing.
Evan W.
#3 Rainer Fritz
Rainer Fritz
Posted 09 November 2007 - 12:21 PM
Evan W.
thank you evan... next week there will come up a making of and some pictures to see a bit more... at thursday there will be the first version of the final video out...
#4 Alex Haspel
Alex Haspel
  • 282 posts
  • vienna, austria
Posted 09 November 2007 - 02:37 PM
Rainer, i KNEW you could not resist for long from posting this! :)
Hi, i was gaffing this, btw.
Thanks again to my fabulous Grip and Electrics Crew on this way, at least to sleepy Anna who also happens to be registered here.
#5 Eirik Tyrihjel
Eirik Tyrihjel
  • 59 posts
  • Oslo, Norway
Posted 09 November 2007 - 06:26 PM
I think it looks very very good, definetly a testimony that RED is delivering - when in good hands!
Thanks for posting the images!
EDIT: oh, by the way - what lenses did you use?
Edited by Eirik Tyrihjel, 09 November 2007 - 06:28 PM.
#6 Rainer Fritz
Rainer Fritz
Posted 09 November 2007 - 09:14 PM
you all did a so great job... everybody will see it in the pictures...
when the final version coming thursday will be ready for publishing, i will post it with a full crew list...
can't wait to see it in the cinema on the big screen and how it will looks when the arri laser did his job.... :)
thanks again...
rainer
#7 Max Jacoby
Max Jacoby
  • 2955 posts
Posted 10 November 2007 - 04:50 AM
The flare on the bassplayer is gorgeous, that's how a lens should look when shooting straight into bright lights!
On the other hand I find the close-up of the girl singing to be unnaturally smooth and plasticky looking, don't like the feel at all I must admit. It's the usual isuse with digital cameras.
The song is nice too, what are the band called?
#8 Alex Haspel
Alex Haspel
  • 282 posts
  • vienna, austria
Posted 10 November 2007 - 12:52 PM
As far as i know, we used Zeiss Highspeed glass, as the MasterPrimes the production aimed for were not awailable.
There have also been some back focus problems as far as i know,
but maybe 1st AC Alex P. who also happens to be a forum member might hop in to clear things up.
#9 Rainer Fritz
Rainer Fritz
Posted 11 November 2007 - 12:59 PM
We had the Red Zoom (18-50) but in case of backfocus problems we didn't used it.
So we had 10,18,25,35,50,85 and 105 Zeiss HS lenses. Not enough budget for the
lovely Master Primes.
The Century 9,5 didn't fit into the pl mount of the red. A known problem, red is
retrofitting a new pl mount design. Mechanical design is not there power....
The Band is called " Herbstrock ".
reg.
Rainer
#10 Alexander pueringer
Alexander pueringer
  • 10 posts
Posted 11 November 2007 - 04:11 PM
Hello Everybody. As to Alex Haspels invitation I jump in the thread. ;)
First I have to correct some minor uncertainties :
We used it once for the last shot. A extreme close up of a car light, here stop 3,5 didn't mater and it was the lens with the shortest closefocus distance on set.
the 105 was actually a 100mm lens.... :ph34r:
The other difficulties with the actual state of the REDcam are mainly hardware ones.
The biggest one is for sure the PL mount. First, when fixing the lens, it has no stop, or latch. So you have to close it like a bottle of water, without feeling a "closed" point. Second, it doesn't take up some lenses. Edwin the owner of #49 RED told me, that this is caused by a slightly different shape of the PL-Mount edges. It should be fixed by the retrofit on the PL-mount RED offers.
As Rainer said:
A known problem, red is retrofitting a new pl mount design. Mechanical design is not there power
The other things which could be listed are:
*Wing nuts already look weak
*The handles for handhold use are kind of dangerous. Its just not possible to safely fix them on the "RED handle mount" as the don't lock tight.
*The cable connectors all are "mini" MiniXLR, MiniBNC etc. which makes no sense to me (but RED already announced a breakout box). The adapter cables are even more filigree.
*The power cable should have a L-plug on the camera side. With steadycam it sort of gets into the way of the battery cage. For Steadycam use I'd recommend the battery plate (if you're shooting on CF cards, but we didn't have one).
*The RED has not a single RS connector for remote focus etc.
That much about the hardware "problems", with the camera in it's actual state.
I'll write a list of "pros" tomorrow, but I have to go to bed now....shooting tomorrow...
Greets Alex
Edited by Alexander P├╝ringer, 11 November 2007 - 04:12 PM.
#11 Rainer Fritz
Rainer Fritz
Posted 13 November 2007 - 01:15 PM
now the fotos are out:
http://redcamservice...pics/index.html
http://redcamservice...ics/index1.html
regards
rainer
#12 Rainer Fritz
Rainer Fritz
Posted 22 November 2007 - 12:01 AM
So the final version is now online:
http://www.redcamser...herbstrock.html
regards
Rainer
#13 David Auner aac
David Auner aac
  • 1117 posts
Posted 22 November 2007 - 03:39 AM
Hi Rainer and crew!
First of all: looks awesome. Did you shoot the tunnel stuff in the newly built U2 underground? What was your kit, Alex, light-wise?
Gruss aus Meidling!
Cheers, Dave
#14 Rainer Fritz
Rainer Fritz
Posted 22 November 2007 - 07:57 AM
Hi David !
Yes it was at the new U2 station "Obere Augartenstra├če".
regards
rainer
#15 Alex Haspel
Alex Haspel
  • 282 posts
  • vienna, austria
Posted 24 November 2007 - 11:04 AM
Hi Rainer and crew!
Gruss aus Meidling!
Cheers, Dave
from my memory, so 100percent accuracy can not be promised:
2 Dinos (30kw each), on dimmerboard
2 5kw spacelights
2 4kw hmi pars
2 2,5kw hmi pars
2 2,5kw hmi fresnels
2 1,2kw hmi pars\
2 120cm fourbanks
2 60cm fourbanks
1 divalight eightbank
2 2kw fresnels
2 1kw fresnels
1 dedokit
and about half a ton of 63A, 32A, 16A cable and various other anschlussmaterial
oh, and a cinejib platfom crane and a panther...
and of course the location has not had any kind of elevator yet <_<
luckily we managed to get hold of a winch from the construction workers, otherwise it
would have been hell hauling al the stuff 4 stories down and then up again
greetings from rudolfsheim,
alex
Edited by Alex Haspel, 24 November 2007 - 11:05 AM.
#16 Anna Baltl
Anna Baltl
  • 24 posts
  • Vienna
Posted 04 December 2007 - 06:19 PM
the making of
http://redcamservice...hbstrkmkof.html
actually a surprisingly nice one ... i like the fight scenes where electricians and grips wrestle 8 stairflights with tonns of equipment in their hands (my body remembered that show particularly well)
#17 Rainer Fritz
Rainer Fritz
Posted 15 January 2008 - 12:15 PM
all stuff moved to the new site:
check it out at: http://www.redcamservice.eu
regards
rainer
