max capacity of an arri IIc mag
#1 adam berk
adam berk
  • 168 posts
Posted 09 November 2007 - 03:44 AM
Does anyone know the real world max capacity of the arri IIc / arri 35III mags?
#2 Henri Titchen
Henri Titchen
  • 125 posts
Posted 09 November 2007 - 04:46 AM
I have loaded and run 200' in a 200' mag with no issues at all.
Henry.
#3 kevin jackman
kevin jackman
  • 350 posts
Posted 09 November 2007 - 10:48 AM
that was priceless. i did see an adaptor a few years ago that attatched a mitchell 1000' mag on a 2c. now im wishing i bid on it.
#4 Rolfe Klement
Rolfe Klement
  • 668 posts
  • London | LA
Posted 09 November 2007 - 03:07 PM
you might be able to squeeze 500ft to 550ft into a 400ft mag. There is a bit of space in there.
I was told you can use some of the Arri 1000ft mags
thanks
Rolfe
#5 John Sprung
John Sprung
  • 4635 posts
Posted 09 November 2007 - 03:34 PM
thanks
Rolfe
Although we call them 400's, the Arri literature back then said 480 ft. Like so many things, they actually do a little better than the manufacturer says.
#6 Hal Smith
Hal Smith
  • 2280 posts
  • OKC area
Posted 10 November 2007 - 10:37 AM
The footage scale on early non-reversal "400 foot" mags is calibrated to 400'. The later reversable mags with the convex lids are the ones with the 480' scale on them. At first Arri called the newer mags "Color Magazines". Apparently the newer mags became necessary because you couldn't load 400' of some color films into the old 400' magazines because the film was thicker. I get the impression that there isn't a "thickness" issue with modern films.
Arri doesn't want you to use a 1000' mag on an Arri 2. I'll bet it has something to do with just how much torque is available from the camera to drive the mag. A 1000' mag might work somewhat but the camera may not be able to maintain constant speed from one end of the film load to the other. Plus the added load might be hard on the camera's gear train.
#7 Leo Anthony Vale
Leo Anthony Vale
  • 2010 posts
  • Pittsburgh PA
Posted 10 November 2007 - 02:50 PM
I recall seeing these in older literature. It has a support frame for placing the camera body in, it's quite probable there's a torque motor attached. After all the Mitchell's pulley isn't compatible with the Arri's gears.
& Arri also made a 1000' AKA 300meter blimp. Don't recall if it used Mitchellm or special Arri mags.
Original 'Wicker Man' used that blimp.
