Blue Screen Test
33 replies to this topic
#1 Daniel Smith
Daniel Smith
  • 791 posts
Posted 20 November 2007 - 02:02 PM
Hi.
I'm currently making a project which will be shot in about 3 weeks time in a studio, against a bluescreen. We are shooting on HD, progressive, 4:2:2 sub-sampling. (DVCPro100)
But before shooting this bluescreen test, I just have a very simple question.
How easy is it to key out the bluescreen?
We will be using Avid HD.
The thing is half the set will be real, the rest will be CGI walls. And there's a strong possibility of shooting behind an actors head and focusing on something behind him. Therefore leaving a blurred actors head against a bluescreen. And I'm quite worried about the bluescreen not keying out correcltly.
We funnily enough have persmission to shoot in Brixton prison however, that defies the object of a bluescreen "test".
As you can tell I've never yet 'really' done any bluescreen work. But I'd still like this project to come out as nicely as possible.
If you've done any bluescreening before or have encountered these kinds of problems please give me a heads up of what to expect, what to do and what not to do.
Thanks.
Posted 20 November 2007 - 02:27 PM
Well, it partly depends on how evenly-lit your bluescreen is and that you made sure not to have any blue spill on the subject, nor that the subject is wearing any blue. Beyond that, your keying software and your proficiency in using it is probably a factor.
As for the out-of-focus head against blue, you should test whether it is better to shoot the object in focus against the blue so you can pull a good matte, and then if you can make it blurry in post before you comp it against the background.
#3 Daniel Smith
Daniel Smith
  • 791 posts
Posted 20 November 2007 - 04:37 PM
Ok I'll probably just have to shoot the actor in focus and blur it later. (From what I know, it won't look 100% natural but there's not a lot else we can do)
As for lighting the screen we have access plenty of kit and a lighting grid so it shouldn't be a problem.
Can you reccomend any other keying software? I've just said we will use Avid because that's what we will use to cut it, but I'm open to any other software if it will do a better job. I have After effects if that is any better.
Thanks.
#4 David Mullen ASC
Posted 20 November 2007 - 04:40 PM
Someone who does post keying work could answer that question better than me.
I would shoot a take with the subject shot to the degree of out-of-focus that you want, so at least you have a reference for how that looks optically.
#5 Daniel Smith
Daniel Smith
  • 791 posts
Posted 20 November 2007 - 06:26 PM
It's only a 3/4 minute length shoot that we will probably have done within 2 hours. (2 hours, filming time that is)
I'll just shoot both, see if I can key out the blue behind the blur, if not revert to the safety shot. I'm getting hold of Ultra2 by Serious Magic. Apparently that is good for keying out blue behind things such as smoke, water etc.
Edited by Daniel Ashley-Smith, 20 November 2007 - 06:27 PM.
#6 Scott Fritzshall
Scott Fritzshall
  • 584 posts
Posted 20 November 2007 - 10:08 PM
My recommendation is that you shoot it correctly against the bluescreen (ie, in-camera defocus), because getting correct defocus blur in post is very difficult. Keying optically defocused material is also very difficult, however, and I'd recommend that you find someone who is more experienced to do it. You'll need to do a lot of spill suppression to get rid of the blue in the transition areas. Really, for this sort of thing, it's best to do the compositing in a dedicated compositing application, such as Shake or Nuke. Shake comes with Primatte and Ultimatte, which are both very good keyers. No keyer is automatic, however, even though most claim to be.
Am I correct in assuming that you'll be shooting on an HVX-200? My understanding is that it's best to shoot in 1080P mode even though it's upsampling to get that resolution, simply because it's also allocating more bandwidth when you do. I read something about that a few months ago, but I don't recall where. The compression is going to hurt you as much as anything else. Blocky artifacts along smooth gradients (such as defocused key edges) are really really painful. If you're going for Standard Definition delivery, however, it's not as big of a deal, because the downsample at the end will blow a lot of that away.
The good news is that getting good results is not terribly difficult with modern keying software. The bad news is that getting GREAT results can take a lot of experience and even when you have it, it's still very tough.
Make sure you shoot it as well as you can. Take detailed notes about every aspect of the camera settings so that you can recreate them when you shoot the other elements. Make sure that you are lighting it in the same manner, and with the same lighting ratios and everything. And of course, try to get your subjects as far away from the blue screen as possible.
#7 Walter Graff
Walter Graff
  • 1334 posts
  • New York City
Posted 20 November 2007 - 10:43 PM
Don't shoot out of focus. You are asking for trouble. You can easily defocus in post. While some myths about how difficult green screen is to deal with exist all over the web, it is really quite easy. If you need more help you can email me or call me.
Shooting in 1080p will offer you nothing noticable as the HVX shoots progressive frames in it's native resolution of 960x540 and uses H & V pixel-shift for greater apparent sharpness but with no real improvement in limiting resolution and then and upsamples to a 1080L
frame buffer, then all output formats are derived from that. 1080 on an HVX is more a marketing gimmick than reality, or should I say not really closer to 1080 than it is to 720.
Read some of my articles on greeenscreen. They may help.
http://www.bluesky-w...reenscreen.html
http://www.film-and-...reenscreen2.htm
http://www.film-and-...eenscreen-6.htm
http://www.bluesky-w...reeenscreen.htm
and examples of how easy an HVX keys:
http://www.bluesky-web.com/HDVHVX.htm
Edited by WALTER GRAFF, 20 November 2007 - 10:44 PM.
#8 Scott Fritzshall
Scott Fritzshall
  • 584 posts
Posted 21 November 2007 - 01:15 AM
Well it is easy to use a defocus filter in post, but the results can vary widely depending on what software you're using, and even with the best (at least regarding off-the-shelf software) you don't always get totally realistic results. I'd say it depends a bit on the content of the shot as well; if you've got really shallow focus on a person's face, for instance, and you want to rack, you're not going to get the natural look of the focus shifting along his face without quite a bit of work if you're doing it in post. It wouldn't hurt him to shoot it all in focus as a safety though.
You're totally right about that, and that was my usual recommendation. I completely forgot where I read that article because it explained the same thing but then also showed that it was allocating it greater bandwidth if you used 1080.
#9 Tim Terner
Tim Terner
  • 340 posts
  • Prague, CZ
Posted 21 November 2007 - 01:29 AM
Hi Daniel, I've found green to be better than blue for digital cameras. A cheapish software that has worked for me is Composite Lab Pro- here's a link to the lite version http://fxhome.com/compositelab/lite - I used this software to do a little test here http://blip.tv/file/361301/ - I found it much better than the built in keying options in Avid and Premiere Pro. Anyway, hope all goes well
#10 Walter Graff
Walter Graff
  • 1334 posts
  • New York City
Posted 21 November 2007 - 07:59 AM
When someone asks a question about a technique he isn't familiar with I always say take the easier step. No filter is perfect when it comes to creating a lens rack but FCP has some great filters for doing the same effect, but I say that too is not about the filter but the talent and experience in knowing how to use it. Given the two options, I'd tell a person newer to the chromakey experience that a post production filter will be a better option than shooting out of focus on a set, but then again I'd really have to know the exact shot and the desired effect to say whether it might be easier to do in post or as a key live. A simple rack can easily be keyed by someone familiar with the intricacies of keying.
Greater bandwidth means little when you don't need it. Having a five gallon bucket for two gallons of water gives you nothing but a bigger bucket with empty space. The HVX is a great prosumer camera, but it is not a full fledge HD camera so trying to find all sorts of headroom is not going to make for a better experience. It's like making a timeline 10 bit when the source is 8 bit. Sounds great but offers little in most all situations other than wasting more hard drive space.
As for green or blue, read my article on why sometimes blue is a better option for keying:
http://www.bluesky-w...eenscreen-6.htm
#11 Daniel Smith
Daniel Smith
  • 791 posts
Posted 30 November 2007 - 02:17 PM
Thanks for the advice it has been very helpfull.
We will be using the Panasonic HD100 (DVCpro100)
For those of you remotely interested I've uploaded the script and storyboards (which took bloody ages)
http://homepage.ntlw....com/bas/dalek/
#12 David Mullen ASC
Posted 30 November 2007 - 04:37 PM
Are you sure you don't mean the JVC HD100 HDV camera? Or the Panasonic HVX200?
#13 Mark Williams
Mark Williams
  • 811 posts
  • United Kingdom
Posted 30 November 2007 - 05:02 PM
Hi Daniel looks like a lot of fun
Hers one I made earlier for something to do!
http://myspacetv.com...ideoid=13684783
#14 Daniel Smith
Daniel Smith
  • 791 posts
Posted 30 November 2007 - 05:06 PM
Oops sorry, I meant the Panasonic HD900.
#15 Daniel Smith
Daniel Smith
  • 791 posts
Posted 30 November 2007 - 05:15 PM
That's pretty ace. Can I ask what equipment and software you used to do this?
Awesome work though. My project won't be quite on the same scale (I'm trying to keep things a minimal as possible, because I always get way ahead of myself)
Cheers.
Edited by Daniel Ashley-Smith, 30 November 2007 - 05:16 PM.
#16 Mark Williams
Mark Williams
  • 811 posts
  • United Kingdom
Posted 30 November 2007 - 05:31 PM
Cheers.
Daniel Thanks!
Yes the film was made with a canon XM2/GL2. Edited in Vegas. Colour corrected, green screened, magic bulleted in After effects. Written by myself. Music was composed in Acid 3. I made the models in C4D version 8.5.
#17 Daniel Smith
Daniel Smith
  • 791 posts
Posted 30 November 2007 - 06:09 PM
Just to confirm, the Panasonic HDX900 (HD version of the SDX900)
Daniel Thanks!
Wow.. that was a pretty clean comp. Did you leave it all to after effects to remove the screen or did you have to manually remove some of it?
Awesome results considering the camera though. (no offence if that's your camera..but it's one of the best jobs I've seen done with a camera of that level)
I guess green screening is the best way to do it with video because of the sub-sampling, green is the only non sub-sampled colour. Unless it's 4:4:4 of course.
Trouble is I only have access to a bluescreen. (Pretty huge bluescreen though)
I've left a comment on the vid anyway.
#18 Mark Williams
Mark Williams
  • 811 posts
  • United Kingdom
Posted 01 December 2007 - 07:32 AM
Thanks Daniel. All done in AE! First of all I made a mask close to the subject then rendered this out. Then deinterlaced before finally keying out what was left. There are many tools in AE for getting a good key. The problem is often with the green/blue screen which has to be lit right and the actor to avoid spill from the screen. Since this I have bought some proper chroma key paint! AND upgraded the sound I'm waitng for a fostex FR2-LE to arrive and finally upgraded my DV camera! One of the hardest shots here was getting the Doctor into the arena with the camera tracking behind the perimeter bars.
#19 Tim Pipher
Tim Pipher
  • 90 posts
  • Los Angeles (Burbank), CA
Posted 01 December 2007 - 10:29 AM
Walter: I loaded and watched your outdoor blue screen pick-up segment from the infomercial -- it was indistinguishable from the original actual location scenes. Well done!
#20 Walter Graff
Walter Graff
  • 1334 posts
  • New York City
Posted 01 December 2007 - 10:38 AM
Thanks. I was under a tough deadline and delaing with about four other projects at the same time. Actually it could have been better. I could have Gaussian blurred her a slight bit more and raised the blacks on her shot to match better the environment she was put in with my back plate, along with a slight bit more edge softening on her. But I was under an deadline to get the updated infomercial on the air and it had to go to a closed caption house first so I made it workable and got it out fast. No one would really notice though. Only when I point it out and show the side by side do most folks see the difference. Other than that, it's done all the time and no one notices. If folks new how many times the shots of folks driving in cars were mattes (even ones that look incredibly real) they would not believe it.
