4K and up on a scissor lift
12 replies to this topic
#1 Daniel Wallens
Daniel Wallens
  • 214 posts
  • Grip
  • New York City
Posted 21 November 2007 - 09:42 PM
Hello all!
I was just wondering about your ideas on putting a 4K or something of similar size on a smallish scissor lift. Our production can't afford more than a 20-footer, but I think I need a little more height than that. A crankovator would be nice, but the base is too big for the lift. I was thinking about rigging a candle stick onto it, but that won't give me much adjustable height.
Any ideas?
#2 Andrew Wheeler
Andrew Wheeler
  • 51 posts
Posted 22 November 2007 - 01:43 AM
Instead of a candlestick you could just rig a combo stand with the legs in with some chain vice grips. I wouldnt go up more that one riser if you do that though.
#3 Michael Nash
Michael Nash
  • 3330 posts
  • Pasadena, CA
Posted 22 November 2007 - 04:16 AM
I wouldn't want to put any weight at the side of a scissor lift (i.e. candlestick). I'd keep the weight in the center of the basket. It's not a condor.
#4 Daniel Wallens
Daniel Wallens
  • 214 posts
  • Grip
  • New York City
Posted 22 November 2007 - 12:58 PM
Well, then why not put the candlestick in the center? Meaning, center lengthwise, against one of the sides.
Andrew,
I was thinking about the stand-with-the-legs-in option as well. But I wasn't sure how accepted a practice or how safe this was.
#5 Jess Haas
Jess Haas
  • 139 posts
  • Santa Monica, Ca
Posted 23 November 2007 - 12:38 AM
The other direction is the least stable so this isn't the best idea. I would put a combo stand in the middle of the basket and ratchet strap it down, especially if you are planning on raising it any.
Scissor lifts don't handle loads on the side as well as condors do so rigging much to the side might not be a great idea.
~Jess
#6 Daniel Wallens
Daniel Wallens
  • 214 posts
  • Grip
  • New York City
Posted 23 November 2007 - 10:24 AM
Well, the thing is, it is going to be a pretty small lift. And as I was saying, I think it will be too narrow to spread out the legs of a stand. Of course, if we were using a like a scaffold, then of course, I'd do it this way.
#7 Jess Haas
Jess Haas
  • 139 posts
  • Santa Monica, Ca
Posted 23 November 2007 - 06:34 PM
Even if you have to have it skinnied up a bit I would think that it would work fine. The legs don't have to be out all of the way as long as you secure it well.
If the lift is small enough to have trouble fitting a stand then I would be concerned about putting much of a load on the edge of the basket. You definitely don't want a load outside of the basket.
~Jess
#8 Matthew Parnell
Matthew Parnell
  • 289 posts
  • Electrician
  • Brisbane, Australia
Posted 24 November 2007 - 07:24 AM
Check your load limits. Remember not to just factor in the weight of your lamphead and balast, but the weight of a lamp op(even if only for the initial focus), the rigging hardware or stands and the cables, even include the weight of the cables right to the ground. Small scissor lifts tend to only have about 90-120kg of weight tolerance.
#9 Jon Rosenbloom
Jon Rosenbloom
  • 713 posts
Posted 25 November 2007 - 05:46 PM
Is this going to play inside or outside? My biggest concern would be making sure the lift is level before it goes up. If it's one of those electric scissor lifts with the hard little tires, you might have trouble driving it onto the leveling blocks. But, if you can get it level, then just chain vice in a candlestick. You can't adjust the height of the candlestick, so if you want to go higher ... get a bigger lift. There's no other answer. All this talk of ratcheting in stands is dangerous and a waste of time. (I think two heights of scaffold, plus a crank-o-vater will get you to 25'.)
Every lift has it's weight capacity printed in an obvious place. Of course, you can ask the rental agency what the capacity is when you order it. At only 20', there's no reason to put the ballast in the bucket. Further, you can focus the light, bring the operator down, and then send the lift back up unmanned.
#10 Daniel Wallens
Daniel Wallens
  • 214 posts
  • Grip
  • New York City
Posted 25 November 2007 - 11:05 PM
This will be playing outside, shining in through a second story window. The height from the ground to the bottom of the window is supposedly 17 feet. The DP estimates that he'll want about a 30-degree angle on the light from above.
The lift I was thinking about was (yes) an electric with hard wheels -- and in my experience, these are quite picky about being on a level surface to operate. But getting a gas wouldn't be as convenient (for sound issues -- we'd have to turn it on/off in order to tweak it). A scaffold is out of the question for other logistical reasons, plus, having a lift makes quick tweaks easier.
Of course, I'd make sure of the weight capacity of the lift. That's not really the issue here. I just was asking for suggestions as to the height (will a 20' lift + candlestick give me a 30 degree angle considering the 17' window?), leveling of an electric lift, and any other ways to get any height out of this setup.
#11 robert duke
robert duke
  • 438 posts
  • Grip
  • southeast USA
Posted 26 November 2007 - 09:23 AM
No, it wont get you the 30' angle you were looking for with only a candlestick. To get anywhere close to your 30' angle the lift would have to be 1-2ft from the window. 17' to bottom of window with a 20' lift. Placing the head of the fixture in the middle of the window, and not filling the window.
You will need a taller lift. Somewhere around 30' is where you need to be in order to get 6' away from the window which is still not very much to allow for the beam to spread. A(squared) + B(squared)= C(squared). Remember geometry.
Spend the money and get a 40' condor. Safety Costs a little more but is worth the extra money.
Leveling a scissor lift is a dangerous game. One wrong move will cost someone a life.
Don't worry about sound they wont be rolling while you adjust the lighting. Production sometimes has to wait while things are focused. Including the camera.
#12 Hal Smith
Hal Smith
  • 2280 posts
  • OKC area
Posted 26 November 2007 - 09:41 AM
The crew I work with at the Oklahoma City Civic Center Music Hall won't go up in their 30' Genie without setting the outriggers, even on a dead flat stage. Levelling and setting outriggers is how you stay alive around tall equipment. It's not a bad idea to wear a harness either.
#13 robert duke
robert duke
  • 438 posts
  • Grip
  • southeast USA
Posted 26 November 2007 - 09:57 AM
There is quite a difference from a scissor lift and a genie manlift. Scissor lifts do not have leveling outriggers. Manlifts are required to have leveling outriggers. A 30' genie only goes 25' up, creating a working height of 30'. I have in the past and learned the error of my ways put a candlestick on a genie with a 6k par. I don't feel safe now with that. It leaves no room for operator.
30' up in a manlift on hardfloors even if they are sprung for dance is much safer than 30' up in a manlift on soil.
