Tri-X Reversal Chemistry
#1 JohnBellville
JohnBellville
  • 6 posts
Posted 25 November 2007 - 11:36 PM
So, I can't find d-96 or d-97 anywhere on the net. I was recommend www.photoformulary.com, but can't find the chemistry. Does anyone know what will work as a substitute for B+W super 8mm reversal chemistry or where to order it? Thanks!
#2 Nick Mulder
Nick Mulder
  • 1023 posts
  • Auckland, New Zealand
Posted 26 November 2007 - 01:01 AM
I use D19 ... its an 'aerial developer' - made for developing aerial photography where apparently they needed a hi-con developer to cut through all the mist etc... - it also keeps the base fog low so you'll get good blacks in the reversal ...
I bought some from freestyle initially but now mix my own with added Sodium Thiocyanate (try your local chem supplier) as a silver solvent ...
If you want I can supply you the formula as the chems aren't too hard to come by usually.
Its great for me as that it also is a good B+W still developer for platinum printing which requires hi-con negs and it also works well as a B+W paper developer - triple usage :D
a little dependent on it you might say ...
Go Team Home-Soup !
#3 JohnBellville
JohnBellville
  • 6 posts
Posted 26 November 2007 - 11:24 AM
Great! I will definitely order some. That would also be excellent if you could supply the chems needed, seeing as I'm a newbie at mixing chemistry/finding chemistry.
#4 Nick Mulder
Nick Mulder
  • 1023 posts
Posted 26 November 2007 - 12:59 PM
goodo ! - have fun, it certainly works ... and once you get your process down the results can be excellent.
Some info here: http://www.apug.org/...ppreciated.html
#5 Charles MacDonald
Charles MacDonald
  • 1157 posts
  • Stittsville Ontario Canada
Posted 26 November 2007 - 09:00 PM
Kodak does have the formulas on their web site, and you can probaly get all the chemicals from www.photoformulary.com, or perhaps http://www.jdphotoch...l/chemicals.htm
#6 Nick Mulder
Nick Mulder
  • 1023 posts
Posted 26 November 2007 - 09:49 PM
Some other chemical suppliers friendly to the photographer:
Bostick & Sullivan
or Artcraft Chemicals where you can buy 15Kg of Silver Nitrate for $4900 and "Rhodium (III) Chloride" for $159 per Gram :o
Edited by Nick Mulder, 26 November 2007 - 09:52 PM.
#7 JohnBellville
JohnBellville
  • 6 posts
Posted 07 December 2007 - 03:52 PM
Ok, so I have D97 as my first developer and kodak sepia toner as my second. I'm just wondering what the processing times should like like for D97. I am developing Tri-x 7266 film. It says on the kodak website 60 seconds (but for D94A)... I've been browsing forums and can't find consistent development times. I'm looking for a good starting point with the film. Help?
#8 Nick Mulder
Nick Mulder
  • 1023 posts
Posted 07 December 2007 - 04:25 PM
'sepia toner' huh ? - you might find its just re-packaged/branded Sodium Sulphide... Stinky chem, but lovely images. The cool thing about reversal is that you can watch them develop before your eyes in the 2nd soup.
As for a starting point in the first developer. No idea with that combo, a search for tri-x at http://www.digitaltr...m/devchart.html yields no hits for D97 - D97 isnt even listed there, but it could still be helpful ... Someone may know the particular characteristics of that developer and cross reference a similar developer at the site - (anyone?) - aside from that, you need to test... shoot 3' or so of the same scene (go for a scene rich in tonality that you can replicate/compare with afterwards) - then develop 1' sections of it for I dunno, um 2mins, 4mins, 8mins - or 3min, 6min, 9 min - 4/6/8 maybe - take a educated guess here ... You'll see a transition from good to worse somewhere.
For 20 year old Plus-X / D19 at 18deg I go for 6minutes and in the summer when the water is more often 20deg I go for 5 minutes - its the same developer I use to tray develop my large format 8x10 negs for platinum printing, with a 200ASA film I use it for 23 minutes/20deg - so you can see the range of different times for different films huh !
Edited by Nick Mulder, 07 December 2007 - 04:27 PM.
#9 JohnBellville
JohnBellville
  • 6 posts
Posted 07 December 2007 - 06:14 PM
Oops, I meant D-76.
