Egbert Mittelstadt's experimental short called "Unfolding"
#1 stephen defilippi
stephen defilippi
  • 45 posts
Posted 02 December 2007 - 07:27 PM
I recently saw this experimental cinema DVD with Egbert Mittelstadt's experimental short called Unfolding.
I did some research and a technique called SLIT SCAN VIDEO was used?? what ever that is.
I can't load any of the footage, but basically the principle image is of a nude dancer moving to some sounds. Behind her is the same image moving from right to left. That image looks like it was "smeared" and so is a continuous smearing of the colors of the dancer who dances in front.
Does anyone who is familiar with the work know how he did this?
Cheers
#2 Will Earl
Will Earl
  • 385 posts
  • Wellington, NZ
Posted 02 December 2007 - 10:12 PM
Haven't seen Unfolding, so I can't comment specifically on it. But in case you haven't found it already there is a good resource for this type of effect here...
http://www.flong.com...ists/slit_scan/
As well as creating some interesting distortion effects, these techniques can sometimes be used to repair image sequences. I remember seeing a Siggraph paper done by Microsoft Research (I think) where they were creating clean background plates using slit-scan techniques.
