Follow Focus Accessory port
13 replies to this topic
#1 Adam Paul
Adam Paul
  • 304 posts
  • Here and now
Posted 11 December 2007 - 05:10 PM
Does anybody know what is the size of the standard Arri accessory port? For me it always looked like one of them socket wrench square fitting ports and recently somebody told me that this is actually what it is. Arri used the same size of one of the available socket wrench fittings, although he wasn't sure which one it actually was. Is this true? Since it works just the same it kind of makes sense Arri would do that in order to keep costs down as you can probably buy OEM parts rather than having them specially made. It would also make it easier for all other manufacturers like Chrosziel to keep the standard.
Thanks.
Edited by Adam Paul, 11 December 2007 - 05:11 PM.
#2 Chris Keth
Posted 11 December 2007 - 06:19 PM
I measured my whip's (made by chrosziel, always has fit FFs I've used) connection and it's 1/2" square. There is a 1/2" drive socket connection but I've never tried, or had reason to try, interchanging parts.
#3 Annie Wengenroth
Annie Wengenroth
  • 653 posts
  • Sound Department
  • Brooklyn, NY
Posted 11 December 2007 - 10:17 PM
It never occurred to me to switch it up either. I accidentally stole a Chroszeil whip from Abel and I sent it back. However. The 1st AC I'm working with tomorrow, owns a Chroszeil whip and we are using the SR3. I did the checkout today and guess what I forgot to add to the package?! So um, I guess we'll find out. I'll let you know if I have to call in an accessory order or not! :lol: ...heh...Oops.
#4 Chris Keth
Posted 12 December 2007 - 04:28 PM
I think you'll be fine. I've used mine with arri follow focuses before.
#5 Kevin Zanit
Kevin Zanit
  • 1223 posts
  • LA
Posted 12 December 2007 - 05:06 PM
I don't know the measurements either, but this does remind me of a funny operation we had to do a few days ago on a show I was shooting.
We had a bunch of hand held stuff in a really small bathroom, and sure enough, oops, no whip. What we did have was a Microforce zoom controller. We just put the motor on the focus gear, the 1st made his distance markings on the controller (the Microforce has a strip of LEDs that indicate the zoom position), and there you have a poor mans wired Preston. It was not the perfect solution, but it worked for the shot quite nicely.
#6 Chris Keth
Posted 12 December 2007 - 05:55 PM
That sounds tricky to control. Maybe I have worked with older microforces but it would be very hard to mix fast and slow movements on the ones I have used.
#7 Kevin Zanit
Kevin Zanit
  • 1223 posts
  • LA
Posted 12 December 2007 - 07:03 PM
It probably wasn't easy, but it was the best option at the time. This was a newer one, it had a slider to go through the range, sort of like the T-stop control on a Preston. The most important thing was that everything was in focus, so I guess it worked!
#8 Chris Keth
Posted 12 December 2007 - 07:18 PM
OK, that would be quite a bit easier than what I was picturing. I envisioned the type with the metal pressure switch and the knob on the end of the handle to adjust the speed.
#9 Annie Wengenroth
Annie Wengenroth
  • 653 posts
  • Sound Department
  • Brooklyn, NY
Posted 13 December 2007 - 12:00 AM
You could do it better with the Arri ZMU-3 since you can program the speeds to slow in and slow out and what-not. Fun times. I do believe that all follow focus whips are created equal.
#10 Chris Keth
Posted 14 December 2007 - 12:26 AM
I assume that means that things worked out fine and you weren't without anything crucial?
#11 Annie Wengenroth
Annie Wengenroth
  • 653 posts
  • Sound Department
  • Brooklyn, NY
Posted 14 December 2007 - 03:40 AM
Yeah it was totally fine...I figured it would be. It's always interesting to me how these different manufacturers end up making pretty much the same stuff that ends up working pretty much the same way. (And that no matter how many subtle variations there are, everyone has their favorites and everyone always bitches about something!)
I do have to say that if there's one camera accessory which I think could go back to the drawing board, it's the eyepiece leveler. I don't know what it is about those freakin things but they hate me, especially Panavision's. But that's another thread for another time. ;)
#12 Satsuki Murashige
Satsuki Murashige
  • 3510 posts
Posted 14 December 2007 - 04:09 AM
They're especially fun to tussle with when there's a DP breathing down your neck and asking "what's wrong, can we shoot yet?" Good times... Hey, at the least the Panavision guys figured out how to make the leveler go up and down on it's own though.
#13 Michael Maier
Michael Maier
  • 216 posts
Posted 14 December 2007 - 08:36 AM
To bring the thread back to topic and in answer to the original question, no, the accessory port is not the same size as any of the socket wrench sizes. The actual port size is not 1/2" but rather just under 1/2". So it fits lose in a 1/2" socket wrench fitting. Chris must have measured his wrongly or not used a caliper. Arri would never make it that easy for DIYs out there. They had to make it just slightly different enough for it to be a specialty part.
Edited by Michael Maier, 14 December 2007 - 08:38 AM.
#14 Chris Keth
Posted 14 December 2007 - 10:09 PM
I just eyeballed it with a tape. Far from the most precise method. Good to know that they won't interchange, I won't even look in the sockets with that in mind now :)
