Let's see your Bolex.
45 replies to this topic
#1 Buddy Greenfield
Buddy Greenfield
Posted 30 December 2007 - 02:11 PM
Not alot happening in here at the moment, so might as well do a "Let's see your Bolex" thread.
Here is my Reflex: Rex 0
Som Berthiot- Cinor - 1.9/10mm RX
Kern -Pizar -1.5/25mm RX
Kern- Yvar- 2.8/75mm
#2 Mike Lary
Mike Lary
  • 472 posts
Posted 30 December 2007 - 06:27 PM
Here's my Rex0 with Vario-Switar 86OE.
#3 Buddy Greenfield
Buddy Greenfield
Posted 30 December 2007 - 09:46 PM
I believe I meant to call mine a Rex 1 as it has the variable shutter.
Very nice Mike. I'd love to get my mitts on a Vario like that, but I need a decent tripod first.
#4 Paul Watt
Paul Watt
  • 12 posts
Posted 31 December 2007 - 03:28 PM
Rex 5 converted to S 16 and SBM by Jean-Louis Seguin. With Les Bosher Bayonet to Nikon Adapter.
Gets it's first test on Wednesday.
#5 Buddy Greenfield
Buddy Greenfield
Posted 31 December 2007 - 05:20 PM
Wow, that bad boy looks fierce!
Are you testing it via spring, motor, or both?
It'd be interesting to see the head everyone has their camera mounted as well.
#6 Rick Johnston
Rick Johnston
  • 4 posts
  • Pemberton, BC
Posted 23 February 2009 - 02:39 PM
SBM converted to Super 16 by Jean-Louis Seguin
(with Vario-Swit 100 POE)
I also use the bayonet to Nikon adapter with my
Nikkor 80-200mm f/2.8D ED
#7 Oliver Christoph Kochs
  • 323 posts
  • Film Loader
  • Germany
Posted 23 February 2009 - 03:21 PM
Bolex Rex 4 Anamorphic Setup
#8 Oliver Christoph Kochs
  • 323 posts
  • Film Loader
  • Germany
Posted 23 February 2009 - 03:24 PM
#9 Oliver Christoph Kochs
  • 323 posts
  • Film Loader
  • Germany
Posted 23 February 2009 - 05:24 PM
EL MK3 Bolex S16 conversion
#10 Rick Johnston
Rick Johnston
  • 4 posts
  • Pemberton, BC
Posted 23 February 2009 - 07:25 PM
sweet Oliver....nice set up!
hey, do you find you need the lens support with the bayonet mount?
they seem hard to find, so i stopped looking.
#11 Oliver Christoph Kochs
  • 323 posts
  • Film Loader
  • Germany
Posted 24 February 2009 - 12:33 AM
Hello Rick,
Regarding the lens support: These are Arri SR1 rods. With very minor plying they fit in the standard Bolex Mattebox hot-shoe. Visual products sells that for $395.
Les Bosher also sells a unit especially for the Bolex which is excellent. You can see these rods in the "Anamorphic Setup" picture. The PL mount is also a Bosher manufacture.
#12 David Auner aac
David Auner aac
  • 1117 posts
Posted 26 February 2009 - 04:32 PM
Hi folks,
here's mine. Rex-5 from '67 with Switars 16/1.8, 25/1.4 and 50/1.4. I also have a 75/2.8 Yvar (seen to the left in one of the pics) and a couple other gimmicks.
Regards, Dave
#13 Herb Montes
Herb Montes
  • 225 posts
  • Gulf Coast of Texas
Posted 04 March 2009 - 07:51 AM
My regular webhosting is down for the moment so I'll have to link to my scrapbook on my deviantART account. Bolex Rex5 with compact zoom and matte box. Shown with Meritek animation motor. Mounted on a Quicket gearhead and pedestal. This setup is for stop motion animation filming.
http://hmontes.devia...Drive-114843197
#14 Anthony Schilling
Anthony Schilling
  • 1063 posts
  • Portland, OR
Posted 15 March 2009 - 10:10 AM
No pics now but:
Bolex Rex 4, serviced recently by Jean-Louis Seguin
Switar 1.9 70mm
Switar 1.4 25mm
Switar 1.8 16mm
Switar 1.6 10mm
Tobin TCS intervolometer, rexofader, flat base grip.
#15 Elliot Rudmann
Elliot Rudmann
  • 208 posts
  • Chicago
Posted 05 April 2009 - 12:53 PM
Here's my Super 16 Bolex EBM - S16 conversion by Meritex Inc./JK Camera, with Les Bosher Bayonet to Canon FD lens adapter. Shot some tests with it this weekend, will post the results probably in about 2 weeks.
Lens shown is Canon FD 50mm F1.4. Also have FD 35mm F2.8 and 24mm F2.8. Will eventually spring for a Switar 10mm and 25mm.
#16 Roberto Pirodda
Roberto Pirodda
  • 112 posts
  • Italy
Posted 10 July 2009 - 01:09 PM
Hey, what about this camcorder-like optical ViewFinder? The only problem is that rotating the eyepiece rotates the image too, i am working to fix it. It is a 16X enlargement eyepiece from an oftalmic equipment, moreover the inside periscope prism has been replaced with 2 first surface mirrors. The image is panoramic and very sharp far better than original 13X VF.viewfinder1.jpg
#17 Jean-Louis Seguin
Jean-Louis Seguin
  • 750 posts
  • Montreal, Canada
Posted 10 July 2009 - 03:35 PM
That's a very weird camera indeed. Nice modification.
I see you have a front from H8RX with a screwed down turret. Is the camera 16mm, regular8 or DS8?
Cheers,
Jean-Louis
#18 Roberto Pirodda
Roberto Pirodda
  • 112 posts
  • Italy
Posted 11 July 2009 - 03:31 PM
Cheers,
Jean-Louis
Hi Jean-Louis
it is a mix- heavily customized camera:the inside mechanic comes from a DS8 round base, the chassis comes from a 16mm SB. i take the 1:1 drive gear from the mechanic of SB, so i can mount an ESM motor. moreover i widened the shutter angle from 170° to about 220-230°, untill maximum permitted by pull-down movement, gaining about 1/2 f-stop. the spring motor is removed, so the camera runs only with electric motor. i removed the friction-speed selector too, that was very noisy, now the camera runs like a fly. Gate widened to MAX8 by the way.
Regards.
#19 Jean-Louis Seguin
Jean-Louis Seguin
  • 750 posts
  • Montreal, Canada
Posted 11 July 2009 - 03:50 PM
Thanks for the info, Roberto.
I am assuming you have eliminated the variable shutter feature to get your 220 degrees?
Cheers,
Jean-Louis
#20 Roberto Pirodda
Roberto Pirodda
  • 112 posts
  • Italy
Posted 12 July 2009 - 03:04 AM
Cheers,
Jean-Louis
no, the variable shutter is always there, it close up to about 90° max, so no fades now but more low light shoots
