Scratched lens.
#1 Buddy Greenfield
Buddy Greenfield
Posted 31 December 2007 - 04:30 AM
I know it?s likely an impossible question to answer, but just how scratched does a lens have to be before it?s completely useless?
Will a few minor scratches not really affect it, or should I just start crying now?
Is there some other use for a scratched lens, like can you have it ground into some kind of special effect lens or something?
Thankfully it?s only a relatively inexpensive 25mm Som Berthiot RX, but on the other hand I?ve been dreaming in shades Ramen noodle just to make my forthcoming project a reality.
Anyone have any decent Ramen recipes?
#2 Chris Keth
Posted 01 January 2008 - 02:13 AM
That is tough to answer. It's doubly difficult since it's something you would notice more at certain stops (probably stopped down) and it will increase the lens' tendency to flare. The real answer is probably that scratches will steadily decrease the performance of a lens and it's up to you when that performance is unsatisfactory.
I have seen photos taken with terrible lenses that looked fine. I even shot with a lens with a cracked element once and saw no adverse effects as long as I kept the lens well flagged or hooded from flare.
#3 Buddy Greenfield
Buddy Greenfield
Posted 01 January 2008 - 04:07 AM
Chris,
I admit, I didn't even consider how the amount of light would play a (now obvious) role.
It should make for decent test fodder.
I appreciate the wisdom in your real answer as I can kind of distill from it the notion that all things considered, the scratches might not be as bad as I think relative to the overall "Quality" of my entire outfit and the level at which I will be realistically using it.
Thank You
Edited by Buddy Greenfield, 01 January 2008 - 04:08 AM.
#4 Hal Smith
Hal Smith
  • 2280 posts
  • OKC area
Posted 01 January 2008 - 11:41 AM
No, but here's a tip from my starving student days: Mackerel in cans is the cheapest high quality protein available. Look up a salmon patty recipe and use mackerel - it's not half bad. By itself mackerel can be quite skanky.
#5 Buddy Greenfield
Buddy Greenfield
Posted 01 January 2008 - 01:01 PM
When it comes to theads that mention skanky mackerel, this one is by far my favorite. :)
#6 Jess Haas
Jess Haas
  • 139 posts
  • Santa Monica, Ca
Posted 01 January 2008 - 03:46 PM
As a lens gets scratches on it it will become softer and flare easier. One trick for fixing things such as chips that create annoying flares is to fill them in with a sharpie. I wouldn't expect that lens to be super sharp to begin with, so it is all about what you determine to be suitable results. I have shot things that turned out great using a set of lenses that were full of fungus. The image was somewhat soft but it worked great for the project.
~Jess
#7 Paul Bruening
Paul Bruening
    (deceased)
  • 2858 posts
  • Oxford, Mississippi
Posted 01 January 2008 - 06:50 PM
An open can of skanky mackerel on set or location can mask the stink of bad acting.
