Increase ProMist Effect in Post?
#1 Tim Nuttall
Tim Nuttall
  • 23 posts
  • New York, NY
Posted 02 January 2008 - 06:57 PM
Hi all,
Is it possible to intensify the effect of say a ProMist filter in post during telecine? What if the image already has a ProMist, but it is of a lower strength?
Thanks.
#2 Adrian Sierkowski
  • 7374 posts
Posted 02 January 2008 - 07:00 PM
I'm going to tenetively say kind-of. A lot of the telecine's iv'e seen have filter effects built in. I know i was able to throw on a silk filter effect in post and also that tiffen just came out with digital versions.
#3 David Mullen ASC
Posted 02 January 2008 - 07:01 PM
Hi all,
Thanks.
You can increase halation by overlaying an image with a Gassian Blur over the sharp image, which gives you more of those glowy effects on highlights. The most tricked-out DaVinci's have this effect in their Color Toolbox -- it is true diffusion, not defocusing. There are other color-correction software that does this but not every DaVinci suite will be set-up to do this. I don't know if a typical DaVinci suite could take a defocused pass or one where a luminence key is defocused, and layer it back over a sharp version of the same shot.
Tiffen also put a ProMist effect in their affordable digital filter package so perhaps you can do it yourself with a computer.
#4 Phil Rhodes
  • 12171 posts
Posted 02 January 2008 - 07:12 PM
...and in some telecines, you could actually put a filter in the gate.
It's now trivial to do promist style effects in even fairly modest postproduction software.
Phil
#5 David Mullen ASC
Posted 02 January 2008 - 08:52 PM
Trouble with that is that you get halation around the blacks, not the whites, because it's a piece of negative that you're shining light through.
