Shooting in PAL Do I need conversion?
#1 VitaSogno
VitaSogno
  • 1 posts
Posted 06 January 2008 - 10:20 AM
Hi all,
Total newbie here, so I hope this makes sense:
My dp will shoot on PD-170p - so PAL only. We'll probably get about 1/3-1/4
of the film done this way--my footage, b-roll, interviews, and trailer. He's
in Milan, and I'm in the States, so after shooting, we'll return to our
respective countries.
A few questions: I'm pretty sure I can edit on Final Cut Pro with PAL,
right? If so, is it better just not to convert to NTSC? We can eventually move PAL
to DVD (is that MP4)? So just two conversions (PAL - DVD) rather than three
(PAL - NTSC - DVD).
Does that work? It's my understanding that converting to NTSC can be pricey
(they charge per hour of footage, not per tape) and there can be glitches
(with sound, so forth).
Can it work like this:
- shoot in pal
- input into final cut pro or like... edit...
- output to digital format (dvd, etc )
At any rate, some people have recommending skipping the whole issue and just
renting/borrowing an NTSC camera, but at this point, It's not possible.
So if you've had any experience in this regard, I'd love to hear from you.
I'd love to hear any thoughts on the easiest way to do this. Ultimately, we'll
put the trailer on . . . probably Quicktime and DVD (not really sure how all
this works) and edit the footage to hold on to for when I have money to go
back and shoot the rest of the film.
Thanks so much!
Darla
#2 Stuart Brereton
Stuart Brereton
  • 3347 posts
Posted 06 January 2008 - 10:55 AM
It's simple, you change your project & capture settings in FCP to DV-PAL in the AV settings menu, then open a new project. Import your footage as normal and edit. When you're done, export the project as a DV-NTSC project via Compressor.
