Loading 100' Dalight into SRII
10 replies to this topic
#1 Peter Anderson
Peter Anderson
  • 96 posts
Posted 13 January 2008 - 06:55 AM
Ive been trawling the forums for info on loading dalight spools into Super16 cameras - Is it as simple as removing the small spool in the arriflex mag and dropping in the metal 100' spool? Afterwards can i then just feed the protective leader through or does it need tearing off?
I have never loaded a 100' spool and am mostly speculating as to what to expect.
#2 Mark Dunn
Mark Dunn
  • 2658 posts
Posted 13 January 2008 - 07:13 AM
There's no separate leader. The paper band just keeps the film tight on the spool before loading. Take it off. It's not attached to the film.
The spool should go onto the spindles after you remove the collapsible cores, but remember you'll need a takeup spool if you want to unload in daylight. If you takeup onto the collapsible core, don't sent it to the lab by accident. Replace it with a 2" core. However, IIRC, 100' on a core won't fit into a 100'can, so you'll need to put the film in a lightproof bag (the sort which comes with film on a core) and then pack it in a 200' or 400' can. The mag may run noisier with all the scraping from the daylight spools, though.
#3 Peter Anderson
Peter Anderson
  • 96 posts
Posted 13 January 2008 - 08:13 AM
Thanks a lot thats cleared a lot up. How easy is it to slide the coreless stock onto a 2" core in a changing bag? I expect it will unravel and be a pain to do. Can i not leave it coreless or will the lab give me grief?
#4 Adrian Sierkowski
  • 7367 posts
Posted 13 January 2008 - 11:25 AM
I've sent in film coreless on occasion and not heard any grief about it. Just write it on the can so they know, is my advice.
Also, you can slip on a 2in core pretty easily, it's a bit or practice though to get it done right. I was doing it with 400' loads but I'm sure a 100' would also be fine. A little unraveling can be ok.
#5 Tim Carroll
Tim Carroll
  • 2168 posts
  • Chicago, Illinois
Posted 13 January 2008 - 12:22 PM
You can see the loading procedure for daylight spools in an Arriflex 16SRII in the camera's Instruction Manual that you can view and download in PDF form here:
Arriflex 16SRII Instruction Manual
It's a 7MB manual, so give it a minute to load.
Best,
-Tim
#6 Andy_Alderslade
Andy_Alderslade
  • 1055 posts
  • London, UK
Posted 13 January 2008 - 12:43 PM
I would also make sure you have some spare 400' cans, if I remember correctly once the 100' of film has been wound up on the Arri core it won't necessarily fit back in a conventional 100' can or box.
I remember this when we tried to put a couple of 100' from an SR11 back in Fuji cans, it was a real squeeze but it did fit in eventually. Better not take the chance though.
#7 Patrick McGowan
Patrick McGowan
  • 173 posts
  • P.A.
  • Brooklyn, NY
Posted 13 January 2008 - 12:52 PM
Is it possible to load 100' spool in an SR3?
#8 Adrian Sierkowski
  • 7367 posts
Posted 13 January 2008 - 12:56 PM
Yep, you can load 100' into an SR3.
#9 Peter Anderson
Peter Anderson
  • 96 posts
Posted 20 January 2008 - 07:27 AM
Just a quick thanks to everyone would helped me out with this post. Loaded and unloaded my first 100' daylight spool into an SR2 without a hitch because of all the great replies. Im in pre-production DoPing my frist 16mm shoot and these forums have been invaluable.
Cheers!
Prokopi
#10 Peter Anderson
Peter Anderson
  • 96 posts
Posted 20 January 2008 - 07:29 AM
Cheers!
Prokopi
#11 Chris Burke
Chris Burke
  • 1720 posts
  • Boston, MA
Posted 20 January 2008 - 09:18 AM
Yes, I've done it a few times for tests
