Motor driven Krasnogorsk K3 - Its here!
#1 Lasse Madsen
Lasse Madsen
  • 2 posts
  • Silkeborg, Denmark
Posted 15 January 2008 - 04:54 PM
Have you been looking at mounting a motor driven, crystal synchronized motor controller to your K3 but are afraid of drilling your camera apart or soldering your fingers together?
And is your arm killing you after numerous rewinds of the spring coil?
Well here's the solution that you've been looking for that even adds a lot of bells & whistles that you?ll only find on more expensive solutions.
The Danish based electronics development company Electro Logic I/S is launching their K3 kit in spring this year which will include some of these features:
  • USB 2.0 connection for firmware updates and speed adjustments etc.
  • Crystal synchronized PLL driven motor controller with current limitation & protection
  • Automatic shutter close function that prevents the shutter from being open at halt
  • Runs on 4 rechargeable AA / LR6 batteries which will give you about five 100 feet rolls
  • 24/25fps selectable through jumper or via USB where you can also set other speeds
  • This implementation requires no soldering iron or drilling of your camera
  • No need for special light meter batteries anymore! ? This is build into the kit.
  • Adjustable light meter voltage for fine trimming your camera
  • Ability to synchronize the camera, with an external tape recorder or similar device.
The kit includes a printed circuit board (PCB) with a specially made gearbox that replaces the spring drive circuitry along with cables, battery compartment and of cause the custom motor ? all in all 7 different parts that needs to be installed into the camera.
Have a look at www.ElectroLogic.dk and tell us here in this forum, what you think of this new innovative solution, as we are currently preparing the kit for production in spring. All comments such as feature requests etc. are welcome.
Thanks in advance
Lasse Madsen
Electro Logic I/S
#2 Leslie Bates
Leslie Bates
  • 7 posts
Posted 15 January 2008 - 09:42 PM
It appears to be a great idea. (I may actually be able to afford the conversion this year.)
What lens and film stock was used for the demonstration film?
How does the generated noise compare to the standard spring powered K3? (I would expect to use a barney when recording sound, but I had to ask?)
#3 Tommy Madsen
Tommy Madsen
  • 5 posts
  • Electrician
  • Denmark
Posted 16 January 2008 - 07:05 AM
As mentioned at the Electro Logic homepage, I am responsible for the K3 - Kit. I will try to answer all questions related to this topic. If You for some reason would like to get in contact with Lasse Madsen, please email him.
We used the standard 17-69mm lense for the demo clip and it was on Ektachrome 100D (Reversal). Regarding the noise, we have measured on both the sprigloaded and with the kit. Result was 53 dBA, measured at a distance of 2 meter in a "lively" room with no carpets on. Hope this will satisfy Your questions.
Regards Tommy Madsen.
#4 Richardson Leao
Richardson Leao
  • 363 posts
  • Stockholm, Sweden
Posted 16 January 2008 - 11:05 AM
what about single frame? cheers
#5 Tommy Madsen
Tommy Madsen
  • 5 posts
  • Electrician
  • Denmark
Posted 16 January 2008 - 11:18 AM
Thanks for Your interest. Yes single frame can be done with the cable release that comes with the camera, or by Timeflow intervalometer from NSC products in NY.
#6 Stewart Munro
Stewart Munro
  • 62 posts
Posted 17 January 2008 - 01:28 AM
how much is it?
#7 Lasse Madsen
Lasse Madsen
  • 2 posts
Posted 17 January 2008 - 02:53 AM
how much is it?
We are planning to release the kit in the range of 500 to 700USD depending on the market demand for it as we want it to be an affoardable solution.
Best regards
Lasse Madsen
Electro Logic I/S
#8 Will Montgomery
Will Montgomery
  • 2072 posts
  • Dallas, TX
Posted 17 January 2008 - 03:19 PM
Don't tease!
Get this thing out soon!
If I had two cameras I'd buy two.
My hand is sore from winding that camera.
#9 Graham Lockey
Graham Lockey
  • 11 posts
Posted 19 January 2008 - 11:26 AM
This is very exciting, I wasn't looking forward to billboarding for an unwanted Tobin.
