Lighting and Outlets
#1 Christopher Logan
Christopher Logan
  • 1 posts
Posted 22 January 2008 - 10:32 AM
I was scouting a location and found this socket...see pictures below. Don't know what it is, the owner seemed to think it was a 60amp but I've read elsewhere it might only be 30amps.
is there a stove tap "like" plug that goes with this socket?
looking to plug in a 2.5K hmi....
#2 Brad Dickson
Brad Dickson
  • 10 posts
Posted 22 January 2008 - 10:40 AM
The fact that both slots are going sideways I suspect it is not 120V but 208V or higher depending upon the location of the intallation. You may want to meter the outlet to see voltage etc.
#3 John Sprung
John Sprung
  • 4635 posts
Posted 22 January 2008 - 02:17 PM
It should be 240 volt 3 wire, i.e., no neutral, just a ground. But do meter it, as these are sometimes installed by people who don't know the code. Here's what the National Electrical Manufacturers Association says about it (scroll down to the diagrams):
http://nooutage.com/...figurations.htm
#4 JD Hartman
JD Hartman
  • 1763 posts
  • Edison, N.J. U.S.A.
Posted 22 January 2008 - 05:29 PM
This is probably a 6-30R, 240v 30amps. So if the HMI ballast will accept a 240vac input, you could build an adapter from a 6-30P cap and a 60A bates.
#5 Andris Kasparovics
Andris Kasparovics
Posted 22 January 2008 - 08:17 PM
Here is a graphic of all NEMA plugs with associated voltages and current capacity
